Re: [gdal-dev] How do I select 3 of 5 bands for output?
Lucena, Ivan ivan.lucena at pmldnet.com
Sat Nov 8 23:34:37 EST 2008
Steve,
I have no experience with "Mr.SID". I don't know the gentleman :).
I don't know if that is a bug or a limitation of this driver.
Best regards,
Ivan
>  -------Original Message-------
>  From: Stephen Woodbridge <woodbri at swoodbridge.com>
>  Subject: Re: [gdal-dev] How do I select 3 of 5 bands for output?
>  Sent: Nov 08 '08 19:30
>  Ahh, thank you for the link to the vrttut. This has got me going in the
>  right direction. I actually did try the -of VRT but didn't know it was
>  supposed to be a XML file so discounted it when the file was small.
>  So, my next problem is that when I run gdalwarp on the VRT file I get
>  assertion errors like the following on about half of the tiles I try to
>  create.
>  $ cat a
>  gdalwarp -srcnodata 0 -dstnodata 0 -s_srs +init=epsg:26916 -t_srs
>  EPSG:4326 -te -86.25 38.3125 -86.1875 38.375 -rb -wm 250 --config
>  GDAL_ONE_BIG_READ ON -co "TILED=YES"
>  /var/data/tiler-tiffs/11234-1226164462/src/tmp.vrt a.tif
>  $ sh a
>  Creating output file that is 6150P x 6150L.
>  Processing input file /var/data/tiler-tiffs/11234-1226164462/src/tmp.vrt.
>  gdalwarp: ../compressed/compressed.cpp:1724: bool
>  kd_tile::read_tile_part_header(): Assertion `tpart_body_length >= 0' failed.
>  a: line 1: 11502 Aborted                 gdalwarp -srcnodata 0
>  -dstnodata 0 -s_srs +init=epsg:26916 -t_srs EPSG:4326 -te -86.25 38.3125
>  -86.1875 38.375 -rb -wm 250 --config GDAL_ONE_BIG_READ ON -co
>  "TILED=YES" /var/data/tiler-tiffs/11234-1226164462/src/tmp.vrt a.tif
>  Is this because the tile extends outside the source image?
>  |  src_image      |
>  |            |  tile    |
>  Or something similar to this? Any thoughts on the cause(s) and workarounds?
>  Thanks again for all the help.
>  -Steve
>  Lucena, Ivan wrote:
>  > Hi Steve,
>  > No, VRT files are not Geotiff, see [1], and they should not take more than a bunch of Kbytes. The problem is that in *our* gdal_translate command line *we* forgot "-of vrt" and the default format is Geotiff.
>  >    system("gdaltranslate -OF VRT $infile -b 1 -b 2 -b 3 tmp.vrt");
>  > Good luck,
>  > Ivan
>  > [1]: http://www.gdal.org/gdal_vrttut.html
>  >>  Sent: Nov 08 '08 03:36
>  >>  Stephen Woodbridge wrote:
>  >>  > Lucena, Ivan wrote:
>  >>  >> Hi Steve,
>  >>  >>>  I have a script that was processing MrSID files and need to convert it
>  >>  >>>  to support jp2 files also. It seems pretty straight forward except the
>  >>  >>>  jp2 files have bands R,G,B,IR and I need to chop these into GeoTif
>  >>  >>> tiles
>  >>  >>>  with only R,G,B bands.
>  >>  >>>  The script was iterating over the src image and chopping it into tiles
>  >>  >>>  using the following command:
>  >>  >>>  system("gdalwarp -srcnodata 0 -dstnodata 0 -s_srs +init=epsg:$epsg
>  >>  >>>  -t_srs EPSG:4326 -te $xm $ym $xx $yx -rb -wm 250 --config
>  >>  >>>  GDAL_ONE_BIG_READ ON -co "TILED=YES" $infile $work/$outd/$outf\n");
>  >>  >>>  1) How does this behave with R,G,B,IR as input and how can I get R,G,B
>  >>  >>>  only into the GeoTif?
>  >>  >> I would add one call to gdal_translate with "-b 1 -b 2 -b 3" first to
>  >>  >> build a VRT and then call gdalwarp from the VRT.
>  >>  >>   system("gdaltranslate $infile -b 1 -b 2 -b 3 tmp.vrt");
>  >>  >> wm 250 --config GDAL_ONE_BIG_READ ON -co "TILED=YES" tmp.vrt
>  >>  >> $work/$outd/$outf\n");
>  >>  >> system("gdalmanage delete tmp.vrt");
>  >>  > OK, this might work, but it is incredibly slow. Then again probably
>  >>  > doing much of anything with these images will be slow because they are
>  >>  > HUGE. So looking for ways to speed this up. It looks like the .vrt file
>  >>  > is really a GeoTif would it help later if the .vrt was made with -co
>  >>  > "TILED=YES", can you do this with a .vrt file. I think the uncompressed
>  >>  > 3 band geoTif will be in the ballpark of 10GB, is this being made as a
>  >>  > BigTiff? or will I run into problems when I hit the 2GB limit?
>  >>  > Anyway to get this to go faster? CPU is at 101%, 78MB of memory is being
>  >>  > used, I have LOTS more if I can get gdal to use it.
>  >>  OK, it took 2 hr 10 min to run:
>  >>  GDAL_SKIP=JPEG2000 gdal_translate
>  >>  /var/data/raw_data/minnesota/ortho_1-1_1m_j_mn161_2008_1.jp2  -b 1 -b 2
>  >>  -b 3 tmp.vrt
>  >>  and the output file is 5.0 GB. And on top of this I still need to
>  >>  gdalwarp this VRT file a bunch of times to chop it into smaller tiles. I
>  >>  have hundreds of files to process. Any thoughts on how to speed this up?
>  >>  -Steve
>  >>  _______________________________________________
>  >>  gdal-dev mailing list
>  >>  gdal-dev at lists.osgeo.org
>  >>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
