[gdal-dev] resampling artifacts
Brent Fraser
bfraser at geoanalytic.com
Mon Nov 10 17:41:01 EST 2008
Even,
It is fixed in v1.6 Beta. Thanks!
Brent
Even Rouault wrote:
> Brent,
> Have you tried with GDAL 1.6.0 beta ? Much work has been done in that area and
> those artifacts should have disappeared and people. See
> http://trac.osgeo.org/gdal/ticket/2627
> Le Friday 07 November 2008 00:08:51 Brent Fraser, vous avez écrit :
>> Has anyone experienced resampling artifacts using gdalwarp?
>> I'm using v1.5.2, and with lanczos or cubicspline resampling, I get a
>> vertical line and a horizontal line of seemingly random pixels about 6
>> pixels wide running through the center of the output image.
>> I'm resampling a 16-bit tif image from 12.5 meters to 200 meters. The
>> other resampling methods result in an ok output image.
>> I've attached a png to illustrate the effect. I thought I'd ask before
>> filing a bug report...
>> Thanks!
>> Brent Fraser
