[gdal-dev] GDAL and numpy, masking arrays
Armin Burger armin.burger at gmx.net
Wed Nov 12 14:48:50 EST 2008
Hi everybody
maybe someone on this list has some experience using numpy in
combination with GDAL/Python and could give me some advice.
I wanted to try to use GDAL/Python/numpy to caculate the difference
between 2 images. The images are vegetation indexes for different dates.
The direct difference can be easily calculated after reading both images
into an array and substract one from the other.
The problem is that both images can contain clouds or snow that have
predefined pixel values (252,253). And I of course would like to exclude
these parts in both images from the calculation because they would cause
wrong results. So I wanted to mask the non wanted areas.
Does anybody know if this is possible and how to perform it? Looking
through the numpy docs I was not able to identify required methods or
functions for this. There is something like 'masked arrays' but I have
not understood if this could be used for my purpose.
Thanks in advance for any help.
Best regards, Armin
