[gdal-dev] NITF TRE support
Dan Greve
grevedan at hotmail.com
Thu Nov 13 11:41:40 EST 2008
Kurt,
I am in the same boat. I have modified the GDAL driver to read AIMIDB and ACFTB similiar to BLOCKA metdata, but I do not have the capability to write these TREs. The TRE creation option should allow this, but I haven't found a good example of how to do this. Hopefully the developer can provide feedback here...
-- Dan Greve
> From: klandrus at progeny.net> To: gdal-dev at lists.osgeo.org> Date: Wed, 12 Nov 2008 11:40:14 -0500> Subject: [gdal-dev] NITF TRE support> > > Ok, I was looking through nithfile.c, am I correct in understanding > that the only TRE supported for saving is BLOCKA, and that each > additional TRE needs to be handled> individually?> > I need to add support for the following TREs. But I don't really need > to add new SDE headers, but preserve the original values as read> using GDALGetMetadataItem.> > SENSRA> AIMIDB> ACFTB> > Is there an easy way to save back an TRE that was read using GDAL (/0 > escaped string)> or should I pull out all the fields from the string, and then > reassemble them in a function as is done for BLOCKA?> > Kurt Landrus> Progeny Systems Corp.> klandrus at progeny.net> Office: 703-368-6107 x424> Lab: 703-368-6107 x520> > > > _______________________________________________> gdal-dev mailing list> gdal-dev at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/gdal-dev
_________________________________________________________________
Color coding for safety: Windows Live Hotmail alerts you to suspicious email.
http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_safety_112008
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081113/19177b21/attachment.html
