[gdal-dev] OGR WFS driver
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 13 12:43:27 EST 2008
Johan Nouvel wrote:
> Hello all,
> I know GDAL has a WMS and WCS driver, but no WFS driver.
> After looking into the mailing list archives I have found no references
> to a WFS driver.
> For my job, we have developped such a driver (in readonly mode, but
> write mode is planned) , based on OGR and its GML driver.
> Is it interesting for GDAL/OGR users to have a WFS driver ? If yes, I
> could spend time to put our code into gdal source (actually it is
> separate from gdal source because of a specific compiling process) and
> then send it in order to be integrated in the svn trunk.
Johan,
We are indeed interested in having a WFS driver for OGR - whether read-only
or read-write. There has been discussion of doing this in the past but
there was never sufficient resources to pursue it.
I'd suggest preparing the driver code and submitting it as a ticket. But,
assuming you are willing, I'd like to propose you as a commiter to take
care of final integration and ongoing support. An existing commiter will
presumably also be involved to do some review and support.
I would like to see such a WFS driver use the existing libcurl interface
(as defined in cpl_http.h) if it doesn't already.
I'm also curious what you do for parsing the GML. Do you process it through
the existing OGR GML driver?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
