[gdal-dev] raw x-y-z height map.
Thu Nov 13 14:02:21 EST 2008
Eran Burstain wrote:
> Hi.
> I want to convert a height map (DTED or other format) to simple ASCII
> file with X,Y,Z coordinates, supplemental data (datums) should be in
> separate file (.vrt), Is there support in such a format ?
Eran,
No, there is currently no direct support for such a format in GDAL.
The gdal/swig/python/scripts/gdal2xyz.py script will produce such a file
but it is not then readable with GDAL, nor can it be referenced from a .vrt
file.
I do frequently use the AAIGRID driver to produce easy to read ascii files,
but it does not produce x/y values for each pixel.
Best regards,
