[gdal-dev] Can I change SOURCE_EXTRA setting at compile time?
Roger André
randre at gmail.com
Tue Nov 18 22:30:05 EST 2008
Hi Frank,
You're absolutely right. Changing those values in mapresample.c to 10
removed the artifacts when using a WMS request. They're still present when
the request is made via mapscript though. I need to manually code a
mapscript example though, because right now I'm testing that via TileCache,
and I'm not 100% certain how the image is being requested. Can you think of
a reason why WMS would be different from a straight read and reproject
through mapscript?
cc'ing TileCache list and mapserver lists as well
On Tue, Nov 18, 2008 at 5:58 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Roger André wrote:
>> Hi Frank,
>> I've theorized all sorts of reasons for what I'm seeing. So far none of
>> them are right. Basically, if I take a really high-res epsg:4326 image, and
>> serve it up through Mapserver in epsg:900913, there are instances where I
>> get images back which are missing rows of pixels at the bottom of the image.
>> If I reduce the resolution of the image the lines go away. I haven't yet
>> figured out at what resolution the problem starts to appear.
>> I just tested the idea of changing the values in the warper code:
>> First:
>> nResWinSize += 100;
>> Then:
>> nResWinSize += 500;
>> Then rebuilt gdal. Didn't seem to make a difference.
> Roger,
> Are you sure the GDAL warper is being used? If the reprojection is being
> done by MapServer it will be using the MapServer warper.
> Try changing the +- 1.0 values to larger values in the following code in
> mapserver's mapresample.c:
> /* Project desired extents out by 2 pixels, and then strip to */
> /* available data. */
> memcpy( &sOrigSrcExtent, &sSrcExtent, sizeof(sSrcExtent) );
> sSrcExtent.minx = floor(sSrcExtent.minx-1.0);
> sSrcExtent.maxx = ceil (sSrcExtent.maxx+1.0);
> sSrcExtent.miny = floor(sSrcExtent.miny-1.0);
> sSrcExtent.maxy = ceil (sSrcExtent.maxy+1.0);
> See if that helps. Currently there is no processing option that does
> what SOURCE_EXTRA does, though it might be worth adding one.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081118/8fd1d423/attachment.html
