[gdal-dev] "gdalwarp -te " units of source or target srs?
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Nov 19 18:25:18 EST 2008
Thanks Even and Frank, you are right I had the order of the coordinate
pairs backwards, Upper-Left Lower-Right instead of L.Left U.Right. I'm
used to using gdal_translate -projwin which uses the former. Is there
any hope of harmonizing the parameters across the utilities so they all
use the same order?
> The -te arguments are in the output file coordinate system.
Perhaps this could be added to http://www.gdal.org/gdalwarp.html for
clarification.
thanks again! (I was really pulling my hair out)
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
> In your case the ymin value is larger than ymax which is causing
> confusion.
> Best regards,
