Re: [gdal-dev] svn trunk build error
Lucena, Ivan
ivan.lucena at pmldnet.com
Fri Nov 21 09:06:54 EST 2008
Hey all,
I made a mistake while adding a driver to the main building process on UNIX (GDALmake.opt.in).
I just fixed it and I contacted Tom, who wrote this original thread, and he confirmed the problem is gone.
Sorry for the disturbance,
Best regards,
Ivan
> -------Original Message-------
> From: Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca>
> Subject: [gdal-dev] svn trunk build error
> Sent: Nov 21 '08 12:17
> using:
> ./configure --with-png --with-libtiff=internal --with-geotiff=internal
> --with-jpeg --with-xerces --with-geos=no --with-pg=/usr/bin/pg_config
> --with-mysql=/usr/bin/mysql_config -
> -with-sqlite --with-curl=/usr/bin/curl-config --with-python --with-expat
> on fc9
> Results in:
> http://rafb.net/p/hXBZxL17.html
> Note that trunk was building successfully previous to this.
> ..Tom
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
