[gdal-dev] autotest 1.6 errors - need help
William Kyngesburye woklist at kyngchaos.com
Sun Nov 30 17:17:27 EST 2008
On Nov 30, 2008, at 4:03 PM, William Kyngesburye wrote:
> - tiff_write
>  TEST: tiff_write_55 ... PROJCS["Equirectangular
> Mars",GEOGCS["GCS_Mars",DATUM["unknown",SPHEROID["unnamed",
> 3394813.857975945,0]],PRIMEM["Greenwich",0],UNIT["degree",
> 0.0174532925199433]],PROJECTION["Equirectangular"],PARAMETER["latitude_of_origin",-2],PARAMETER["central_meridian",184.4129943847656],PARAMETER["standard_parallel_1",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
> fail
>    failed to preserve Equirectangular projection as expected, old
> libgeotiff?
> Well, I'm using geotiff 1.2.5, and I notice that GDAL includes 1.2.4.
> It's not saying what the difference is.
Tried with internal geotiff, no change.
Also note: I'm using a CVS trunk libtiff from Mar 2008.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
