[gdal-dev] opendap on Windows
Michael Sumner
mdsumner at utas.edu.au
Wed Oct 1 17:16:37 EDT 2008
Hello,
I got this to work on a different machine. Clearly something I have done
on the original
machine was causing a problem, or there are network connection problems
I need to investigate.
This is how I set it up:
1. Install MS VC++ 2008 (9.00)
2. Obtain GDAL source
3. Run batch file to generate project file
[gdal]/makegdal_gen 9.00 > makegdal90.vcproj
4. Open project file in MSVC, edit nmake.opt
- GDAL_HOME
- DODS_DIR:
DODS_DIR = C:\opendap
DODS_LIB = $(DODS_DIR)\lib\libdapMD.lib
$(DODS_DIR)\lib\libdapclientMD.lib
5. Install the following from http://www.opendap.org/download/libdap++.html
libdap_3.8.2.exe - C:\opendap
(http://www.opendap.org/pub/binary/libdap/win32/libdap_3.8.2.exe)
OPeNDAP_Tools_1.1.exe - C:\opendap-tools
(http://www.opendap.org/pub/binary/libdap/win32/OPeNDAP_Tools_1.1.exe)
6. Copy the contents C:\opendap-tools\include directory to
C:\opendap\include\
7. Restart Windows.
8. Build the project, check with tests:
gdalinfo
"http://www.marine.csiro.au/dods/nph-dods/dods-data/climatology-netcdf/gordon_atlas.nc?temperature[y][x]"
gdalinfo
"http://dods.jpl.nasa.gov/opendap/sea_surface_temperature/avhrr/pathfinder/data_v5/8day/descending/04km/2006/bsst/2006001-2006008.s0481pfv50-bsst.hdf?bsst[y][x]"
gdal_translate
out.tif -outsize 400 200
Thanks again for the help, and patience.
Regards, Mike.
> Subject:
> Re: [gdal-dev] opendap on Windows
> From:
> Michael Sumner <mdsumner at utas.edu.au>
> Date:
> Tue, 30 Sep 2008 15:21:31 +1000
> To:
> condit at sdsc.edu, gdal-dev at lists.osgeo.org
> To:
> CC:
> Hello,
> I'm afraid that while it seems to build correctly there is a runtime error
> "An unhandled Win32 exception occured in gdalinfo.exe"
> I don't know how to proceed to figure this out. I've tried building GDAL
> in release mode, and also without the /MD flag - but with the same
> result. The access to other formats works fine regardless.
> I'm using these dataset urls, both of which work on Linux:
> gdalinfo "http://www.marine.csiro.au/dods/nph-dods/dods-data/climatology-netcdf/gordon_atlas.nc?temperature[y][x]"
> gdalinfo "http://dods.jpl.nasa.gov/opendap/sea_surface_temperature/avhrr/pathfinder/data_v5/8day/descending/04km/2006/bsst/2006001-2006008.s0481pfv50-bsst.hdf?bsst[y][x]"
> Thanks for any help,
> Cheers, Mike.
> ==============Original message text===============
> On Tue, 30 Sep 2008 8:13:46 +1000 "Christopher Condit" wrote:
> Hi Mike-
>> Thank you for the feedback - I have tried copying the
> curl/xdr/pthreads
>> headers into the libdap/include folder - and editing the top level
>> nmake.opt to DODS_DIR. There just were a number of unclear steps (for
>> me) so I'll go back and try again, then report back more completely. I
>> will provide the full steps if I ever succeed.
> Here's my configuration:
> DODS_DIR = C:\develop\lib\libdap3.8.2
> And then I added the includes from the "Tools" distribution to the
> include dir (preserving the directory hierarchy). If you're still having
> trouble building perhaps attach a copy of the errors from nmake. I'm
> also using VS 2005.
>> I also gather that the instructions for MSVC in the GDAL FAQ should
> be
>> completed - I've only done the "atlbase.h" step as that seemed to
> allow
>> the build in general to finish. Any idea if the other steps would
>> impact the Opendap build?
> As far as I know these instructions are for the "Express Edition". I
> didn't have to make any changes to my VS installation.
> -Chris
> ===========End of original message text===========
