[gdal-dev] Re: OziExplorer (ozf2) Files with GDAL?
Tom Kazimiers
2voodoo at gmx.de
Fri Oct 3 07:37:03 EDT 2008
Jukka Rahkonen schrieb:
> Oliver Eichler <oliver.eichler <at> gmx.de> writes:>
>> AFAIK the ozi format is just referencing information to a bitmap stored in a
>> known format like jpeg, png or tiff. Thus using gdal_translate is not that
>> obscure to me.
> Hi,
> Not quite so. OziExplorer .map file it doing that, pointing out to the image
> file and giving projection, datum and set of reference points for OziExplorer
> moving map program. Ozf is a special file format tailored for OziExplorer and
> it is the only format supported by PDA version OziExplorer. It is having tiles,
> colour palette and overviews, all good things in getting speed and low memory
> need. Unfortunately it is not documented, but my guess is that tiles are pngs.
> This is what the author of OziExplorer writes:
> What is the OZFx3 Image Format
> The OZFx3 format stores the image in tiles, each tile can be manipulated as a
> single unit.
> Advantages
> * Contains a separate image for each zoom level for 25% and below. These
> zoom levels are created using a bilinear filter and look good.
> * Zooms of 90, 80, 75, 70, 60, 50, and 40% are created by OziExplorer and
> OziExplorerCE using a bilinear filter giving good looking smooth zooms.
> * Fast Initial Loading
> * Small memory requirement when loaded
> * The loaded tiles can be cached in memory, this allows the OZFx3 format to
> be efficiently used on slow Windows CE PDA's.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Jukka,
thank you for the hints. Like written in an earlyer post the tiles are
64x64 pixels each. Each pixel has the size of ony byte and is
referencing a color palette.
Regards,
Tom
