[gdal-dev] Ingres driver for gdal
Denise MacLeod
Denise.MacLeod at ingres.com
Mon Oct 6 11:11:31 EDT 2008
Hi -
I am another recent addition to the GDAL community. I am currently using the Ingres driver for the latest svn trunk version. I had originally downloaded the driver back in May, and had it working, but the latest version wasn't working for me; specifically ogr2ogr was seg faulting.
After some digging, I found out that the command line syntax had changed between May and now. Previously, this syntax worked:
ogr2ogr -overwrite -append -skipfailures -f ingres INGRES:mydbname road.shp
Now however, the syntax is (as documented on the GDAL website):
ogr2ogr -overwrite -append -skipfailues -f Ingres "@driver=ingres,dbname=mydbname,user=mydbuser,password=mypwd" road.shp
I was wondering if there's a reason to have the syntax so different from some of the other formats, such as Postgres? (with the @ sign at the beginning). Also, out of curiousity, is the new driver parameter used to separate the vector format (specified by "-f Ingres") from the driver used?
Finally, I fixed the seg fault by initializing the data source pointer as such:
from ogr/ogrsf_frmts/ingres/ogringresdriver.cpp
OGRDataSource *OGRIngresDriver::CreateDataSource( const char * pszName,
char ** /* papszOptions */ )
> OGRIngresDataSource *poDS = NULL;
Thanks,
Denise
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081006/3c095e27/attachment.html
