[gdal-dev] ogr option-spat
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 9 09:35:19 EDT 2008
Guillaume Sueur wrote:
> Weird to say why it doesn't work when you don't know yourself what it
> should really do...
> This option (and not function) is designed to extract a specific extent
> of your input data when using ogr2ogr.
> Actually it SHOULD work as I use it really often. Check your
> data/values/result, and provide more precise test case if it doesn't.
Folks,
The only thing I might add is that -spat does not actually clip
the returned geometries. It returns all features whose geometries
touch the selection region but it returns the geometries intact, not
clipped.
Lionel, I think you will need to supply a specific example that
is not working for us to followup. I will say that the spatial
filtering is done by the individual driver and there is always the
chance that some drivers do not do it properly.
Best regards,
> GOUBET LIONEL a écrit :
>> Hi,
>> How use the options –spat XMIN YMIN XMAX YMAX ?
>> I try but it doesn’t work … All data layer is returned (same if I add in
>> a table these columns).
>> What’s the problem ? What’s the utility of this focntion ?
>> Thanks you
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
and watch the world go round - Rush | Geospatial Programmer for Rent
