[gdal-dev] ogr option-spat
GOUBET LIONEL
goubetli at yahoo.fr
Thu Oct 9 13:47:01 EDT 2008
OK Frank and Guillaune
Here are more precisions:
1. I work with OSGEO4W with plugins oci.
2. My datatable is a table Oracle spatial with a column geometry.
3. If I launch ogr.exe with -sql select * from myTable or with -sql select * from myTable -spat XMIN YMIN XMAX YMAX => the result is the same.
That's the reasons why I don't understand.
Do you have a example?
> Actually it SHOULD work as I use it really often. Check your
> data/values/result, and provide more precise test case if it doesn't.
Guillaume, what's your database ?
Thanks you very much
----- Message d'origine ----
De : Frank Warmerdam <warmerdam at pobox.com>
À : guillaume.sueur at neogeo-online.net
Cc : GOUBET LIONEL <goubetli at yahoo.fr>; gdal-dev at lists.osgeo.org
Envoyé le : Jeudi, 9 Octobre 2008, 15h35mn 19s
Objet : Re: [gdal-dev] ogr option-spat
Guillaume Sueur wrote:
> Weird to say why it doesn't work when you don't know yourself what it
> should really do...
> This option (and not function) is designed to extract a specific extent
> of your input data when using ogr2ogr.
Folks,
The only thing I might add is that -spat does not actually clip
the returned geometries. It returns all features whose geometries
touch the selection region but it returns the geometries intact, not
clipped.
Lionel, I think you will need to supply a specific example that
is not working for us to followup. I will say that the spatial
filtering is done by the individual driver and there is always the
chance that some drivers do not do it properly.
Best regards,
> GOUBET LIONEL a écrit :
>> Hi,
>> How use the options –spat XMIN YMIN XMAX YMAX ?
>> I try but it doesn’t work … All data layer is returned (same if I add in
>> a table these columns).
>> What’s the problem ? What’s the utility of this focntion ?
>> Thanks you
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081009/e7c2f580/attachment.html
