[gdal-dev] Re: EASE-grid projection
Dan Stahlke
dan at gina.alaska.edu
Fri Oct 10 14:09:38 EDT 2008
Jose,
The north pole version works for me, perhaps because of the '+init='
part: (although that probably shouldn't matter...)
gdalwarp -t_srs '+init=epsg:3408' ...
Maybe the equatorial version of EASE is different.
If you are giving the full proj4 definition "+proj=cea ..." you might
try adding "+no_defs" at the end. Otherwise, you usually end up getting
some sort of default flatting value or something that tends to interfere
whenever an explicit radius is specified. Probably the "+ellps=sphere"
ends up overriding the faulty default value.
- Dan
Jose Gomez-Dans wrote:
> Hi,
> I know it's unpolite to reply to self, but I think I might have
> cracked this one. Comments welcomed...
> 2008/10/10 Jose Gomez-Dans <jgomezdans at gmail.com
> <mailto:jgomezdans at gmail.com>>
> $ gdalwarp --debug on -of GTiff -s_srs "+proj=cea +lat_0=0
> +lon_0=0 +lat_ts=30 +a=6371228.0 +units=m" -t_srs 'EPSG:4326'
> INPUT OUTPUT.tif
> OGR_PROJ4: Can't find ellipse definition in:
> +proj=cea +lat_0=0 +lon_0=0 +lat_ts=30 +a=6371228.0 +units=m
> ERROR 1: Translating source or target SRS failed:
> If I add the +ellps=sphere (hint is here:
> <http://nsidc.org/data/ease/ease_grid.html#whySpherical>. What's wrong
> with having a flat Earth!!! :D), I am able to reproject the data.
> Is this a sound approach?
> Thanks,
> Jose
> Centre for Terrestrial Carbon Dynamics
> Department of Geography, University College London
> Gower Street, London WC1E 6BT, UK
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
