[gdal-dev] gdal and python problems
Andreas Neumann
a.neumann at carto.net
Tue Oct 14 10:24:44 EDT 2008
I was compiling gdal with python support from svn-trunk and ran into the
same problem as described at
http://www.nabble.com/Problem-with-gdal_polygonize.py-td19839558.html
When I start a python script I get the following error message:
gdal_merge.py -o orthofoto_2008.tif -init 255,255,255 -v -co
"COMPRESS=PACKBITS" -of GTiff OF_10cm/69*.tif
File "/usr/local/bin/gdal_merge.py", line 31, in <module>
import gdal
File "/usr/local/lib/python2.5/site-packages/gdal.py", line 2, in <module>
from osgeo.gdal import deprecation_warn
File "/usr/local/lib/python2.5/site-packages/osgeo/gdal.py", line 7, in
<module>
import _gdal
ImportError: /usr/local/lib/python2.5/site-packages/osgeo/_gdal.so:
undefined symbol: GDALPolygonize
My system is Ubuntu 8.10 (Intrepid Ibex). I used the following configure
options:
./configure --with-perl --with-python --with-xerces --with-sqlite
--with-pg=/usr/local/pgsql/bin/pg_config --enable-bigtiff
--with-odbc=/usr/lib --with-libtiff=internal
--with-grass=/usr/local/grass-6.3.0
Here is the output of configure:
GDAL is now configured for x86_64-unknown-linux-gnu
Installation directory: /usr/local
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: grass57+
CFITSIO support: no
PCRaster support: internal
NetCDF support: no
LIBPNG support: external
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: external
LIBGIF support: internal
OGDI support: no
HDF4 support: no
HDF5 support: no
Kakadu support: no
JasPer support: yes (GeoJP2=no)
ECW support: no
MrSID support: no
MSG support: no
GRIB support: yes
cURL support (wms/wcs/...):yes
PostgreSQL support: yes
MySQL support: no
Ingres support: no
Xerces-C support: yes
NAS support: no
Expat support: yes
ODBC support: yes
PGeo support: yes
OCI support: no
SDE support: no
DODS support: no
SQLite support: yes
DWGdirect support no
PANORAMA GIS support: no
INFORMIX DataBlade support:no
GEOS support: yes
Old-gen python no
SWIG Bindings: python perl
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: no
hide internal symbols: no
Maybe I am missing some python packages. On Ubuntu 8.10 there are a
gazillion of python packages. I made sure I installed the swig and sip,
incl. the dev packages.
Any idea what went wrong with my install or which package I am missing?
Thanks,
Andreas
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
