[gdal-dev] OGR and C#
Tamas Szekeres szekerest at gmail.com
Wed Oct 15 17:00:22 EDT 2008
Jerry,
It depends on which drivers/features are actually used by your OGR
script, my best advice is to copy *.dll into your executing directory.
You could narrow down the required set of the dll-s by inspecting the
dependencies by using the dependency walker tool or use SysInternals
filemon to see which dll-s have been loaded at run-time.
Best regards,
Tamas
2008/10/15 Jerry O'Sullivan <jeremiahosullivan at gmail.com>:
> Hi,
> I have got OGR working in my C# app by adding FWTools bin folder to PATH
> during run-time. I would like to be able to distribute my application
> without the requirement for the user's PC to have FWTools installed.
> Is it possible to just include the dlls in the bin folder and if so what
> dlls do I need
> Any advice would be greatly appreciated
> Thanks,
> Jerry
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
