[gdal-dev] Supporting ECW as GDAL plugin.
Andreas Neumann a.neumann at carto.net
Thu Oct 16 06:48:24 EDT 2008
Hi Daniele,
You need to install the ecw libraries. For Unix/Linux/MacOSX you need to
compile from source. You can get the libraries from
http://www.ermapper.com/ProductView.aspx?t=131 - after installing the
libraries you need to tell gdal where to find them and re-compile gdal.
I don't know what the exact licence terms are. It is a commercial product
and in the past there was a limitation that files with the public version
could not grow past 500MB in size, which is pretty severe limitation.
The binary versions fwtools (http://fwtools.maptools.org/) should contain
ecw support, but I don't know if the limitation exists or not.
Because of this limitation I am currently not using ecw.
Maybe there was a change in the licence terms, however. I am not totally
up to date.
See also http://www.gdal.org/frmt_ecw.html
> Hi list,
> I would like to get some information about how to support ECW as a GDAL's
> plugin.
> Andrea Aime, back from the FOSS4G, have proposed to improve the support to
> ECW format offered by our ImageIO-Ext project,
> by leveraging on GDAL plugin mechanism.
> Which steps are involved to support ECW Driver as a plugin? (on both
> Windows/Linux).
> Should I also tweak the java bindings generation step to handle this?
> Any information/suggestion/link would be greatly appreciated. (I have
> already taken a look at ticket 2385)
> Thank you very much.
> Regards,
> Daniele
> Eng. Daniele Romagnoli
> Software Engineer
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax:     +39 0584983027
> mob:   +39 328 0559267
> http://www.geo-solutions.it
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
