Re: [gdal-dev] visual leak detector support
Lucena, Ivan
ivan.lucena at pmldnet.com
Fri Oct 17 10:38:22 EDT 2008
Hi Norman,
I think that Mateusz would be the person to answer it better and I am not doing much use of MSVC this days, but I
remember seen a message from VLD coming up at the end of the execution, on the output window, even using
those makefile projects (makgdal71.vcproj). Basically all the debugging functionalities work for those kind of VC
project, there is not reason why VLD shouldn't. I believe that VLD should also work on command line. You probably
need to change some setting on VLD to tell where to write the report. But you are right, it is not working anymore.
I think we need to check the compilation/debugging flags to see what is going on. There was a big change at some
point (a year ago?...) and it might be affecting the use of VLD.
Best regards,
Ivan
> -------Original Message-------
> From: Norman Barker <nbarker at ittvis.com>
> Subject: [gdal-dev] visual leak detector support
> Sent: Oct 16 '08 17:32
> Hi,
> I see that visual leak detector support has been added to gdal nmake.opt,
> and I have turned this on.
> However the visual studio project files use a make file configuration,
> how do you actually get the leak detector to work?
> The docs at [LINK: http://trac.osgeo.org/gdal/ticket/2009]
> http://trac.osgeo.org/gdal/ticket/2009 are a little sparse.
> thanks,
> Norman
> gdal-dev mailing list
> [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
