[gdal-dev] OGR: GetField methods problem
Anton Patrushev
anton at orkney.co.jp
Tue Oct 21 02:44:39 EDT 2008
Hi Andrey,
Of course I'm linking GDAL :)
But I finally got it!
Somehow I was using different versions of gdal and gdal-dev packages
(gdal-dev was newer).
Cheers,
Anton.
On 10/21/08, Andrey Kiselev <dron at ak4719.spb.edu> wrote:
> Anton,
> On Sat, Oct 18, 2008 at 11:45:49AM +0900, Anton Patrushev wrote:
> > It is strange, but I have this problem again with the fresh
> > installation of Ubuntu 8.04.
> > I took GDAL 1.5.1 .deb packages from here
> > http://les-ejk.cz/ubuntu/dists/hardy/multiverse/binary-i386/ and they
> > look OK.
> > But when I'm trying to compile my stuff, I get
> > /usr/include/gdal/ogr_feature.h undefined reference to
> > 'OGRFeature::GetFieldAsDouble(int)'
> > 'OGRFeature::GetFieldAsInteger(int)'
> > 'OGRFeatureDefn::GetFieldIndex(char const*)'
> > just like with RHEL before.
> > It looks pretty strange, 'cause I have all header files from gdal-dev.
> That means you forgot to link with the GDAL library. Try to add '-lgdal'
> option to you compilation command line.
> Best regards,
> Andrey
> Andrey V. Kiselev
> ICQ# 26871517
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
