[gdal-dev] to write earth coordinates into NITF image subheader
Tue Oct 21 11:20:57 EDT 2008
Mo Wang wrote:
> Hi all,
> There is a function called NITFReadBLOCKA_GCPs in nitfimage.c that can
> read earth coordinates for image corner locations in the NITF image
> subheader to provide higher precision. Is there a function that can
> write higher precision earth coordinates into the NITF image subheader?
> Is there an option in gdal_translate so that the earth coordinates can
> be written into the NITF image subheader? Thanks in advance.
Mo,
Currently GDAL does not support creating a BLOCKA segment automatically
from GCPs.  If you know exactly what you are doing, you can create BLOCKA
segment but you need to pass the appropriate creation options when creating
the NITF file.  There is some documentation of this in:
   http://www.gdal.org/frmt_nitf.html
Best regards,
