[Gdal-dev] gdal_grid: Comments from a new player
Andrey Kiselev dron at ak4719.spb.edu
Wed Oct 22 03:34:14 EDT 2008
On Tue, Oct 21, 2008 at 11:01:36PM -0700, Fodder wrote:
> The latest version of GdalGrid (in FWTools) seems to not use the
> radius values properly for the Nearest algorithm. In my project, I
> used 4000 for both but I ended up with very little circles around the
> data points. Using the same radius values for the Inverse Distance
> algorithm produced values for the entire display (which is what I
> would expect because my entire project is 4000x4000).
I have found (and fixed) the small problem introduced with my previous
fix for
 http://trac.osgeo.org/gdal/ticket/2237
It goes in trunk and 1.5 brunch.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
