[gdal-dev] Odd things after using ogr2ogr
Kai Behncke
Kai-Behncke at gmx.de
Thu Oct 23 05:01:29 EDT 2008
Dear Frank,
thank you for that hint.
> I imagine there is an issue with how the datum shifting is being done.
> It looks to me that by default EPSG:31467 does not have datum shift
> parameters supplied with it (as expected by GDAL/OGR).
Is there a possibility to put this datum shift parameters manually?
> Even if they are the same version, I would suspect that one way there
> are proper datum shift parameters being used, and the other way there
> are not.
In which way there are proper datum shift parametes used?
Thank you very much again, Kai
GMX Kostenlose Spiele: Einfach online spielen und Spaß haben mit Pastry Passion!
http://games.entertainment.gmx.net/de/entertainment/games/free/puzzle/6169196
