[gdal-dev] Build OGR with ESRI SDE
Tamas Szekeres szekerest at gmail.com
Thu Oct 23 08:45:21 EDT 2008
Steve,
If you require a Windows based build, you should identify the location
of your SDE client lib and header files and modify your gdal nmake.opt
accordingly:
SDE_ENABLED = YES
SDE_VERSION=92
SDE_PLUGIN = YES
SDE_SDK = C:\arcgis\arcsde
SDE_INC = $(SDE_SDK)\include
SDE_LIB = $(SDE_SDK)\lib\pe$(SDE_VERSION).lib \
          $(SDE_SDK)\lib\sde$(SDE_VERSION).lib
$(SDE_SDK)\lib\sg$(SDE_VERSION).lib
In a Visual Studio command prompt you can do something like:
> cd [GDAL_DIR]\ogr\ogrsf_frmts\sde
> nmake /f makefile.vc ogr_SDE.dll
> cd [GDAL_DIR]\frmts\sde
> nmake /f makefile.vc plugin
Best regards,
Tamas
2008/10/23 Mullins, Steven <Steven.Mullins at dmme.virginia.gov>:
> I am interested in using OGR to read data from an ArcSDE (9.2-9.3) database.  The manual page at http://www.gdal.org/ogr/drv_sde.html indicates that GDAL must be compiled "with the ESRI provided ArcSDE client libraries".
> Before I sink a lot a time into this, can anyone share their experience compiling OGR with ESRI libraries for SDE?  What specific steps need to be taken to accomplish this?
> Thanks in advance for your help.
> Steve
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
