[gdal-dev] Build OGR with ESRI SDE
Mullins, Steven Steven.Mullins at dmme.virginia.gov
Thu Oct 23 10:41:57 EDT 2008
Thanks everyone for the pointers.  I assume the Linux version compiles with GCC.  From what I read, Visual Studio is needed for a win32 compile, which I do not have.  Any chance I could do this with GCC in win32?
Thanks again,
Steve
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thu, October 23, 2008 10:20 AM
To: Mullins, Steven
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Build OGR with ESRI SDE
Mullins, Steven wrote:
> I am interested in using OGR to read data from an ArcSDE (9.2-9.3) database.
> The manual page at http://www.gdal.org/ogr/drv_sde.html indicates that GDAL
> must be compiled "with the ESRI provided ArcSDE client libraries".
> Before I sink a lot a time into this, can anyone share their experience
> compiling OGR with ESRI libraries for SDE?  What specific steps need to be
> taken to accomplish this?
Steve,
On linux this boils down to setting one or both of:
   --with-sde=DIR        Include ESRI SDE support (DIR is SDE's install dir).
   --with-sde-version=VERSION NUMBER  Set ESRI SDE version number (Default is 80)
when configuring.  On Windows setting of:
#SDE_ENABLED = YES
#SDE_VERSION=91
#SDE_PLUGIN = NO
#SDE_SDK = C:\arcgis\arcsde
#SDE_INC = $(SDE_SDK)\include
#SDE_LIB = $(SDE_SDK)\lib\pe$(SDE_VERSION).lib \
#          $(SDE_SDK)\lib\sde$(SDE_VERSION).lib
$(SDE_SDK)\lib\sg$(SDE_VERSION).lib
in gdal/nmake.opt
I'd appreciate someone setting up a topic on SDE under:
   http://trac.osgeo.org/gdal/wiki/BuildHints
if interesting information is collected.
Best regards,
