[gdal-dev] Is it possible to "hide" some ERROR messages?
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Fri Oct 24 03:36:28 EDT 2008
Hi list,
Is it somehow possible to customize/hide some GDAL error messages?
I know error messages are really useful to fix/understand problems.
Anyway, let me expose my use case:
I simply need to check if I can obtain a Dataset for a file and return a
boolean.
If I get a Dataset, great! Otherwise... no problem. :)
The user won't see messages like this "ERROR 4: `c:\mydataformat.frmt' not
recognised as a supported file format" (although by this way he will never
know why no Dataset has ben acquired).
Is there some setConfigOption("xxx",) to hide (some) error messages?
Thank you.
Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081024/901beb6b/attachment.html
