[gdal-dev] JPEG2000 question/issue
Nidel, Mike
mike.nidel at lmco.com
Mon Oct 27 11:38:48 EDT 2008
Interesting. I'd like to disable NITF handling, is this also possible
in the same way using GDAL_SKIP? Where is the definitive list of format
names that can be used in this way?
thanks,
Mike
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
> Sent: Monday, October 27, 2008 11:24 AM
> To: Christiaan Janssen
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] JPEG2000 question/issue
> Christiaan Janssen wrote:
> > I'm wondering if someone can help me with this. I'm trying to build
> > GDAL with both support for MrSID and ECW while using the former for
> > JPEG2000 support. It appears that as soon as libecw is
> linked in, it
> > is being used as the JPEG2000 reader (even when I have
> MRSID_FLAGS =
> > -DMRSID_J2K uncommented in the make options). I'm assuming this
> > probably has something to do with the order that the
> drivers are tried
> > at runtime. Is there a correct way to force the support to
> default to
> > the MrSID library? Thanks for the help.
> Christiaan,
> Disabling the -DMRSID_J2K should disable the JP2MRSID driver
> though you may need to do a clean build for the change in the
> nmake.opt to take effect.
> Alternatively you can force a particular driver to be ignored
> at runtime using the GDAL_SKIP configuration variable. Set
> it to the driver name you want to ignore ... such as JP2MRSID.
> It can be set in the environment, before running GDAL commands.
> set GDAL_SKIP=JP2MRSID
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
> gdal-dev mailing list
