[gdal-dev] Re: No support for widestrings in ArcSDE driver for
OGR ?
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 27 16:32:50 EDT 2008
Ragi Y. Burhum wrote:
> On Mon, Oct 27, 2008 at 8:33 AM, <gdal-dev-request at lists.osgeo.org
> Hi all
> Throughout GDAL 1.5 and 1.6+ I havent been able to reading most
> strings from ArcSDE using OGR, which is probably caused by the
> ArcSDE drivers lack of widestring support (?). Is this correct, or
> am I doing something wrong ? I'm pretty desperate for this to work
> now. Seems as if a lot of ArcSDE data is stored as widestrings,
> which seriously limits the applicability of my connection. Could
> anyone give me an update on this ? I've tried looking at the tickets
> but failed to find an entry that adressed this issue. Thanks,
> Anders.
> Starting from 9.3 (or was it 9.2?) the strings created by ArcCatalog are
> widestring by default. I took a quick look at ogrsdelayer.cpp and
> ogrsdedatasource.cpp and that code is only consuming the non-Unicode API.
> Frank: I did see that OGRSDELayer::Initialize(..) maps an OGR
> OFTWideString (a type that the documentation says it is deprecated) to
> an SDE widestring (i.e. SE_NSTRING_TYPE) if #SE_NSTRING_TYPE is defined,
> however OGRSDELayer::TranslateSDERecord() does not have a case statement
> for SE_NSTRING_TYPE (and therefore has no call to SE_stream_get_nstring
> <http://edndoc.esri.com/arcsde/9.3/api/capi/schemaobjects/streams/strmgetnstring.htm>).
> A quick fix to at least be able to consume the sde unicode strings would
> be to add that case for that switch statement and take the result and
> encode the UTF16 string to UTF8.
> I would fix it myself and submit a patch, but ironically enough, I don't
> have a way to test it or compile it since I don't have ArcSDE nor ArcGIS
> anywhere... should I submit a ticket?
Ragi,
I'm in the same position - no SDE instance to test against. A patch might
be good if either Howard or Anders are willing to commit to testing it out.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
