[gdal-dev] Python / ArcGIS / zlib conflict
Christopher Barker Chris.Barker at noaa.gov
Tue Oct 28 12:25:55 EDT 2008
Gregory, Matthew wrote:
> It seems strange to me that ArcGIS would put the 'bin'
> directory (that had all kinds of other stuff besides Python DLLs) into
> PYTHONPATH, but I may not have a good grasp of the complexities here ...
My rant:
Why the heck do folks using python to script their own tools use a
standard install, but then treat python as their own little playground?
It makes it very difficult to use Python as a general purpose
development tool if ESRI, or whoever, is messing with the environment.
If you want to use python to script your own stuff, either do a private
install, or DO NOT mess with anything global, such as PYTHONPATH.
Sorry, I don't have a solution that won't break ESRI stuff, but I am
telling you that the problem is what they've done, NOT your grasp of the
complexities.
sigh.
-Chris
no wait -- one possible option: it appears you're having difficulties in
the build/install stage -- if that's it, then you may be able to simply
re-set PYTHONPATH before running setup.py
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
