[Gdal-dev] SQLite problem
iomeneandrei
aborruso at tin.it
Wed Oct 29 14:52:41 EDT 2008
Hi all,
I have created a sqlite spatial db with ogr2ogr, starting from a simple
shapefile.
I'm able to read the proper info of this sqlite db with ogrinfo.
If I add a column to this sqlite db inside the table where I have the
WKT_GEOMETRY, ogrinfo is no more able to read properly this db.
Is it possible to add a column to a sqlite spatial db without destroy the
spatial component?
I'm using SQLite Manager 0.3.15 for firefox to edit the db.
I'm attaching the original sqlite file:
http://www.nabble.com/file/p20233548/output1.sqlite output1.sqlite
Thank you,
Andrea
Andrea Borruso
email: aborruso at tin.it
blog: http://blog.spaziogis.it
View this message in context: http://www.nabble.com/SQLite-problem-tp20233548p20233548.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
