[Gdal-dev] SQLite problem
Even Rouault
even.rouault at mines-paris.org
Wed Oct 29 18:49:09 EDT 2008
Yes, see http://www.sqlite.org/lang_altertable.html
You need SQLite > 3.1.3
Le Wednesday 29 October 2008 23:44:37 Even Rouault, vous avez écrit :
> I can read output2.sqlite with ogrinfo:
> INFO: Open of `output2.sqlite'
> using driver `SQLite' successful.
> Layer name: output
> Geometry: Point
> Feature Count: 2
> Extent: (13.000000, 38.000000) - (13.500000, 39.000000)
> Layer SRS WKT:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.01745329251994328,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]]
> testo: String (0.0)
> xi: String (0.0)
> yi: String (0.0)
> test: String (0.0)
> OGRFeature(output):1
> id (String) = 1
> testo (String) = ciao
> xi (String) = 13.000000
> yi (String) = 38.000000
> test (String) = (null)
> POINT (13 38)
> OGRFeature(output):2
> id (String) = 2
> testo (String) = bau
> xi (String) = 13.500000
> yi (String) = 39.000000
> POINT (13.499999999999996 39.0)
> I believe having read somewhere that old versions of sqlite libraries
> didn't handle well changing the structure of a table after its creation. Is
> there any chance that your GDAL build links to an old sqlite library ?
> Le Wednesday 29 October 2008 23:39:19 iomeneandrei, vous avez écrit :
> > Hi Frank,
> > thank you very much.
> > Frank Warmerdam-2 wrote:
> > > The file you referenced seems to work fine with my (trunk) ogrinfo.
> > > Can you
> > > provide an example that ogrinfo can't read? Generally, adding new
> > > columns to
> > > a spatial table should not cause problems for OGR.
> > The file I have attache was the right one.
> > I have used this query:
> > ALTER TABLE "main"."output" ADD COLUMN "test" VARCHAR
> > And I have had the file I'm attaching now
> > http://www.nabble.com/file/p20237327/output2.sqlite output2.sqlite .
> > I'm not able to read it with ogrinfo.
> > My sqlite client is this:
> > https://addons.mozilla.org/en-US/firefox/addon/5817
> > Thank you,
> > Andrea
> > Andrea Borruso
> > email: aborruso at tin.it
> > blog: http://blog.spaziogis.it
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
