Frank Warmerdam schrieb: > > Are you referring to an alpha band? If so, you could select a subset of > bands with gdal_translate using the -b flag. > > > eg. > > gdal_translate -b 1 -b 2 -b 3 rgba.tif rgb.jpg > > Best regards, Hello Frank, thanks for your help, this worked! Sometimes the solution is too simple. Wolfgang
