[gdal-dev] in memory KML
    Mateusz Loskot
    mateusz at loskot.net
    Wed Apr  1 06:23:31 EDT 2009
Frank Warmerdam wrote:
> Clay, Bruce wrote:
>> After a bit more digging I am not sure I asked the right question.
>> What I want to do is read feature information from a shapefile or
>> other data source and get a string that contains the feature
>> information encoded in KML that I can pass directly into Google
>> Earth.  I know I can do this operation is I open the shapefile write
>> the KML data to disk then open the kml file up with fopen then read it
>> into memory and send it t Google Earth but I would like to save the
>> disk write the read operation.
>> Any thoughts?
> Bruce,
> I've skimmed the KML driver and there is no sign that it uses the VSI*L
> API for file access, so I don't see any way you can write results to a
> memory buffer without substantial recoding in the kml driver.
Looks like a candidate for proposal for the GSoC 2009
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
