[Gdal-dev] xml file for accessing to a wcs server
salwa
belasalwa at yahoo.fr
Wed Apr 1 06:38:19 EDT 2009
Hi Frank,
this is my WCS service description file:
<WCS_GDAL>
<ServiceURL>http://localhost:81/cgi-bin/mapserv.exe?map=NDVI.map&SERVICE=WCS&CRS=EPSG:26191&</ServiceURL>
<CoverageName>NDVI</CoverageName>
<supportedCRSs>EPSG:26191</supportedCRSs>
<PreferredFormat>gtiff</PreferredFormat>
<GetCoverageExtra>&BBOX=279728,114867,296168,125307&time=2002-11-07</GetCoverageExtra>
<Version>1.0.0</Version>
<BlockXSize>551</BlockXSize>
<BlockYSize>351</BlockYSize>
<BandCount>1</BandCount>
<BandIdentifier>bands</BandIdentifier>
<BandType>Byte</BandType>
</WCS_GDAL>
and the Mapfile :
MAP
NAME wcs
STATUS ON
SHAPEPATH "C:/PROJ/R3"
INTERLACE ON
TRANSPARENT ON
UNITS METERS
DEBUG ON
PROJECTION
"init=epsg:26191"
END
LAYER
NAME "NDVI_index"
STATUS OFF
#DATA DATA/NDVI/NDVI_9i2e_R3
DATA ndvi.shp
FILTERITEM 'TIME'
FILTER '%time%'
UNITS METERS
TRANSFORM TRUE
DEBUG ON
TYPE tileindex
PROJECTION
"init=epsg:26191"
END
DUMP TRUE
END
LAYER
NAME "NDVI"
STATUS OFF
UNITS METERS
TRANSFORM TRUE
DEBUG ON
TYPE RASTER
TILEINDEX "NDVI_index"
PROJECTION
"init=epsg:26191"
END
DUMP TRUE
METADATA
"wcs_name" "NDVI"
"wcs_label" "NDVI R3"
"wcs_abstract" "blabla"
"wcs_description" "blabla"
"wcs_bandcount" "1"
"wcs_rangeset_name" "bands"
"wcs_rangeset_label" "bands"
"wcs_rangeset_axes" "bands"
"wcs_formats" "gtiff"
"wcs_srs" "EPSG:26191"
"wcs_extent" "279728 114867 296168 125307"
"wcs_resolution" "30 30"
"wcs_timeitem" "_date"
"wcs_timeposition" '2002-09-01,2002-11-07,2002-12-25,2003-01-26,2003-02-11,2003-02-27,2003-03-31,2003-04-16,2003-05-18,2003-08-31'
END
END
END
Thanks for help,
Best regards,
View this message in context: http://n2.nabble.com/xml-file-for-accessing-to-a-wcs-server-tp2566259p2568319.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
