[gdal-dev] gdalwarp and image size change
erik
whatevar89 at gmail.com
Sat Apr 4 05:09:52 EDT 2009
I'm new to gdal, geotiffs & stuff, so sorry if this all seems obvious.
I've been trying to reproject a geotiff from "+proj=utm +zone=29 +ellps=intl
+units=m +no_defs" (European 1950, zone 29 - Portugal) to WGS84.
gdalwarp -s_srs "+proj=utm +zone=29 +ellps=intl +units=m +no_defs" -t_srs
"+proj=latlong +datum=WGS84" map.tif map3.tif
The original file is 5366 x 3387
but ... the reprojected file is 5695 x 2863
With the naked eye I can't see much change. Is this behaviour normal?
Concerning the original file, it was built with gcp's in gdal_translate and
then warped in the original projection. Maybe this isn't enough? In the
ozi2geotiff.py script I see he does a second translate with several creation
options (-co) for tiled, block(x,y)size, compress and predictor. As well as
some other stuff with convert, listgeo and geotifcp.
Thanks,
Erik.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090404/2848ee80/attachment.html
