[Gdal-dev] How to enable MSG DRIVER
APOSTOLOS
agiannas at geo.auth.gr
Tue Apr 7 04:12:31 EDT 2009
Dear list
in order to clear the mess i sum the following things i have made:1) created a folder frmts/msg and extracted there my Wavelet 2.04 2) I followed the instructions for the patch for wavelet and changed the libraries 3) I have also downloaded a patch and saved it in frmts/msg/PublicDecompWT (the patch includes many filles like msgcommand.cpp, msgcommand.h......)
The only configure like file i found is the one that Frank created. Do i save it in the folder frmts/msg/PublicDecompWT like the others and in order to configure do i have to rename configure.in?
Thanks in Advance
On Monday 06 April 2009 16:01:24 Apostolos Giannakos wrote:
> Dear Warmerdam,
> First i would like to thank you for your immediate response
> The problem is that when i run ./configure --with -msg in the /frmts
> and it doesn;t find the file
The configure script is in the main directory (i.e., you download the source
tarball, uncompress it, cd into the created directory, and issue
your ./configure command).
Jose
RSU ■ Dept. of Geography ■ University College ■ Gower St, London WC1E 6BT UK
EMM ■ Dept. of Geography ■ King's College ■ Strand, London WC2R 2LS UK
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
View this message in context: http://n2.nabble.com/MSG-Interface-tp2024510p2597626.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
