[Gdal-dev] Read and convert MSG2 hrit data with GDAL-MSG DRIVER
APOSTOLOS agiannas at geo.auth.gr
Thu Apr 9 09:03:38 EDT 2009
Dear list
>From the gdal_translate command the MSG DRIVER reads only MSGN native. Does anyone know even if i have made the configure command and instaled the MSG DRIVER  why i can;t import HRIT wHEN I try to run the procedure? it gives me
tolis at ubuntu:~/gdal-1.6.0$ gdal_translate -of HFA '/home/tolis/H-000-MSG2__-MSG2________-IR_087___-000007___-200802280000-C_' /home/tolis/Desktop/out_hrit.img
ERROR 4: `/home/tolis/H-000-MSG2__-MSG2________-IR_087___-000007___-200802280000-C_' not recognised as a supported file format.
GDALOpen failed - 4
in case someone else wants it the gdal_translate command to convert to img from MSG .nat files is
tolis at ubuntu:~$ gdal_translate -of HFA '/home/tolis/Desktop/2003/06/05/MSG1-SEVI-MSG15-0100-NA-20050919001240.662000000Z-596358.nat' /home/tolis/Desktop/OUTPUT.img
Input file size is 1504, 1052
0...10...20...30...40...50...60...70...80...90...100 - done.
tolis at ubuntu:~/gdal-1.6.0$ gdal_translate --formats
Supported Formats:
  VRT (rw+): Virtual Raster
  GTiff (rw+): GeoTIFF
  NITF (rw+): National Imagery Transmission Format
  RPFTOC (ro): Raster Product Format TOC format
  HFA (rw+): Erdas Imagine Images (.img)
  SAR_CEOS (ro): CEOS SAR Image
  CEOS (ro): CEOS Image
  JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
  GFF (ro): Ground-based SAR Applications Testbed File Format (.gff)
  ELAS (rw+): ELAS
  AIG (ro): Arc/Info Binary Grid
  AAIGrid (rw): Arc/Info ASCII Grid
  SDTS (ro): SDTS Raster
  DTED (rw): DTED Elevation Raster
  PNG (rw): Portable Network Graphics
  JPEG (rw): JPEG JFIF
  MEM (rw+): In Memory Raster
  JDEM (ro): Japanese DEM (.mem)
  GIF (rw): Graphics Interchange Format (.gif)
  ESAT (ro): Envisat Image Format
  BSB (ro): Maptech BSB Nautical Charts
  XPM (rw): X11 PixMap Format
  BMP (rw+): MS Windows Device Independent Bitmap
  DIMAP (ro): SPOT DIMAP
  AirSAR (ro): AirSAR Polarimetric Image
  RS2 (ro): RadarSat 2 XML Product
  PCIDSK (rw+): PCIDSK Database File
  PCRaster (rw): PCRaster Raster File
  ILWIS (rw+): ILWIS Raster Map
  SGI (rw+): SGI Image File Format 1.0
  SRTMHGT (rw): SRTMHGT File Format
  Leveller (rw+): Leveller heightfield
  Terragen (rw+): Terragen heightfield
  GMT (rw): GMT NetCDF Grid Format
  netCDF (rw): Network Common Data Format
  HDF4 (ro): Hierarchical Data Format Release 4
  HDF4Image (rw+): HDF4 Dataset
  ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
  ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
  PDS (ro): NASA Planetary Data System
  ERS (rw+): ERMapper .ers Labelled
  JPEG2000 (rw): JPEG-2000 part 1 (ISO/IEC 15444-1)
  L1B (ro): NOAA Polar Orbiter Level 1b Data Set
  FIT (rw): FIT Image
  GRIB (ro): GRIdded Binary (.grb)
  RMF (rw+): Raster Matrix Format
  WCS (ro): OGC Web Coverage Service
  WMS (ro): OGC Web Map Service
<MSGN (ro): EUMETSAT Archive native (.nat)
  RST (rw+): Idrisi Raster A.1
  INGR (rw+): Intergraph Raster
  GSAG (rw): Golden Software ASCII Grid (.grd)
  GSBG (rw+): Golden Software Binary Grid (.grd)
  GS7BG (ro): Golden Software 7 Binary Grid (.grd)
  COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
  TSX (ro): TerraSAR-X Product
  COASP (ro): DRDC COASP SAR Processor Raster
  PNM (rw+): Portable Pixmap Format (netpbm)
  DOQ1 (ro): USGS DOQ (Old Style)
  DOQ2 (ro): USGS DOQ (New Style)
  ENVI (rw+): ENVI .hdr Labelled
  EHdr (rw+): ESRI .hdr Labelled
  GenBin (ro): Generic Binary (.hdr Labelled)
  PAux (rw+): PCI .aux Labelled
  MFF (rw+): Vexcel MFF Raster
  MFF2 (rw+): Vexcel MFF2 (HKV) Raster
  FujiBAS (ro): Fuji BAS Scanner Image
  GSC (ro): GSC Geogrid
  FAST (ro): EOSAT FAST Format
  BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
  LAN (ro): Erdas .LAN/.GIS
  CPG (ro): Convair PolGASP
  IDA (rw+): Image Data and Analysis
  NDF (ro): NLAPS Data Format
  EIR (ro): Erdas Imagine Raw
  DIPEx (ro): DIPEx
  LCP (ro): FARSITE v.4 Landscape File (.lcp)
  RIK (ro): Swedish Grid RIK (.rik)
  USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
  GXF (ro): GeoSoft Grid Exchange Format
  HTTP (ro): HTTP Fetching Wrapper
  HDF5 (ro): Hierarchical Data Format Release 5
  HDF5Image (ro): HDF5 Dataset
  ADRG (rw+): ARC Digitized Raster Graphics
  BLX (rw): Magellan topo (.blx)
Dear list
First all i would like to thank all the people in the list answered my questions. I finally managed to install MSG DRIVER but i have some questions about how to import and convert HRIT MSG2 images with GDAL
I followed the example of the instructions from http://www.gdal.org/frmt_msg.html but i did not manage  to convert HRIT to tif.
My code bellow
gdal_translate -of MSG(/home/tolis/Desktop/2003/06/05/H-000-MSG2__-MSG2_PAR____-WV_062___-000001___-200802281200-C_) /home/tolis/Desktop/output/outfile.tif
bash: syntax error near unexpected token `('
Any suggestions what i am doing wrong?   Also what i realy want is to convert MSG2 HRIT thermal bands  for segments 7 and 8 to images to brightness temperatures. Because i have 96 images per day is there any batch process for this kind of procedure?
Does GDAL support this procedure?
Thanks in advance for your time
View this message in context: http://n2.nabble.com/Read-and-convert-MSG2-hrit-data-with-GDAL-MSG-DRIVER-tp2609915p2610947.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
