[gdal-dev] Problem in importing to Google Earth a nitf image
converted from a tif image by gdal_translate
Vincent Schut
schut at sarvision.nl
Fri Apr 10 03:15:11 EDT 2009
mohwawang wrote:
> Hi Roger,
> gdalinfo gave me only info about coordinates of GCPs but I doubt that are much useful to GE. Any other way (other than using GCP in gdal_translate) to embed the coordinates info to the GeoTIFF file?
Mo,
I doubt GE will read and use your gcp's. And as there is not
georeferencing (as: standard geotiff georeferencing) in your tiff, GE
will fail to place your image.
I'd try to run your tiff through gdalwarp instead of gdal_translate.
Good chance that gdalwarp will convert your unprojected image with gcp's
into a real projected geotiff.
Just try: 'gdalwarp <inimage.tif> <outimage.tif>' and then check your
outimage with gdal_info. It should now give you proper lat/lon values
for the corner coordinates, instead of pixel indices.
Vincent.
> Thanks.
> Mo
> Driver: GTiff/GeoTIFF
> Files: gdal_translate_tif_to_gtiff.gtf
> Size is 561, 420
> Coordinate System is `'
> GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
> GCP[ 0]: Id=1, Info=
> (0,0) -> (-70.887525562763,42.8093748999134,0)
> GCP[ 1]: Id=2, Info=
> (560,0) -> (-70.887525562763,42.8082925732318,0)
> GCP[ 2]: Id=3, Info=
> (560,419) -> (-70.8894939447889,42.8082925732318,0)
> GCP[ 3]: Id=4, Info=
> (0,419) -> (-70.8894939447889,42.8093748999134,0)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_XRESOLUTION=300
> TIFFTAG_YRESOLUTION=300
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 420.0)
> Upper Right ( 561.0, 0.0)
> Lower Right ( 561.0, 420.0)
> Center ( 280.5, 210.0)
> Band 1 Block=561x4 Type=Byte, ColorInterp=Red
> Band 2 Block=561x4 Type=Byte, ColorInterp=Green
> Band 3 Block=561x4 Type=Byte, ColorInterp=Blue
> --- On Thu, 4/9/09, Roger André <randre at gmail.com> wrote:
>> From: Roger André <randre at gmail.com>
>> Subject: Re: [gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
>> To: "mohwawang" <mohwawang at yahoo.com>
>> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
>> Date: Thursday, April 9, 2009, 4:30 PM
>> Hi Mo,
>> What is the gdalinfo output for the GeoTIFF that you
>> created? If you didn't get an error when you tried to
>> load it in GE, perhaps the georeferencing in the image
>> doesn't quite match what you specified in your KML.
>> Roger
>> On Thu, Apr 9, 2009 at 1:21 PM,
>> mohwawang <mohwawang at yahoo.com>
>> wrote:
>> Hi Roger,
>> My goal is to be able to directly import NITF image to GE
>> without using KML. You can see the advantage of this
>> application - if it works. I'm glad that you have viewed
>> in GE georeferenced imagery created or altered by gdal.
>> Maybe you can point out what I did wrong.
>> It is good that you asked about GeoTIFF. So I used
>> gdal_translate to convert the tif image to a GeoTIFF image.
>> I tried to drag and drop the GeoTIFF image to GE but nothing
>> happened. I did not see the GeoTIFF image in GE and I did
>> not get any error message either.
>> I can open the GeoTIFF image with OpenEV and I can read the
>> lan/lon coordinates and they are correct. One thing is that
>> it seems that OpenEV does not set North to Up. Its
>> orientation aligns with the file coordinates - (0,0) is at
>> the upper left corner. I then opened tif file in the same
>> OpenEV and they match to each other.
>> Again, I can import the tif image with its kml to GE but I
>> can not import the GeoTIFF to GE (without using kml), it
>> seems that nothing happened. I can import the GeoTIFF to GE
>> with kml - though that is not what I want. But the GeoTIFF
>> is better than the NITF that could not be imported to GE
>> even with the same kml.
>> What's wrong with GeoTIFF? I mean why I could not
>> import it to GE? I listed the gdal_translate command line
>> here:
>>> gdal_translate -of GTiff tiff.tif gtiff.gtf -a_srs
>> EPSG:4326 -gcp 0 0 -70.887525562763 42.8093748999134 -gcp
>> 560 0 -70.887525562763 42.8082925732318 -gcp 560 419
>> -70.8894939447889 42.8082925732318 -gcp 0 419
>> -70.8894939447889 42.8093748999134
>> I don't have a .ntif file that was not created by gdal
>> to test GE via the "Import Image Tool".
>> Thanks.
>> Mo
>> gdal_translate
>>> Date: Thursday, April 9, 2009, 12:47 PM
>>> Hi Mo,
>>> Thanks for that pointer on the differences between GE
>>> Layers and Places. I'll be sure to take a close
>> look
>>> at those links. I've had occasion in the past to
>> view
>>> georeferenced imagery in Google Earth, much of it
>> created or
>>> altered by gdal in some way, so this topic interests
>> me.
>>> I'm curious, is your goal to view the NITF format
>>> specifically and to have GE read the internal
>> georeferencing
>>> info, or is it just to view the image in GE? It
>> sounds
>>> like you have already accomplished the latter using a
>> KML
>>> Ground Overlay and a tif, a method which has also
>> worked
>>> reliably for me in the past as well. I've also
>> had
>>> success with PNG and JPEG format files.
>>> Since in your .nitf test the georeferencing was
>> supplied by
>>> the KML file, the red "X" you are getting
>> implies
>>> to me that the image format isn't being correctly
>>> interpreted by GE for some reason. The fact that
>> Envi
>>> chokes on it as well does seem to point to gdal as a
>>> possible culprit, although the NITF format is not one
>> that I
>>> have seen very much. Have you tried importing the
>> GeoTIFF
>>> version of your file directly into GE Pro as well?
>> Also,
>>> do you have a .nitf file that was not created by gdal,
>> and
>>> which you could use to test GE via the "Add
>> Image
>>> Overlay" tool?
>>> Roger
>>> On Thu, Apr 9, 2009 at 8:37 AM,
>>> wrote:
>>> Roger,
>>> I'm using Google Earth Pro 5.0. Thank you for the
>>> suggestions.
>>> Google Earth Pro 4.0 also supports importing NITF:
>>> http://earth.google.com/userguide/v4/ug_importdata.html
>>> that is for importing your data (including vector data
>> and
>>> imagery data) to the Places of Google Earth while http://earth.google.com/userguide/v4/ug_imageoverlays.html
>>> is for "Using Image Overlays and 3D
>> Models".
>>> See http://earth.google.com/userguide/v4/ug_layers.html#layers_vs_places
>>> for the difference between Layers and Places in GE.
>>> This is the first time I'm importing
>> geo-referenced
>>> images to Google Earth Pro and so far I don't have
>> much
>>> luck. As I said that I could not use GE to import the
>> NITF
>>> images converted from gdal_translate (with EPSG:4326
>> that is
>>> the same projection, Simple Cylindrical projection, or
>> known
>>> as Lat/Lon WGS84 that GE uses). So I tried to narrow
>> down
>>> the problem. This time I imported to GE an native
>> Erdas
>>> IMAGINE image (.img) (with UTM projection that GE
>> supports
>>> too) but still failed. The later test case has nothing
>> to do
>>> with gdal and is purely a question for GE. That .img
>> image
>>> can be opened by both IMAGINE and OpenEV.
>>> The NITF image (converted by gdal_translate) not just
>> could
>>> not be opened by GE it could not be opened by ENVI
>> 4.1
>>> either. It can be opened by OpenEV (tightly related to
>> gdal)
>>> though. So it could be a problem in either
>> gdal_translate or
>>> ENVI (I doubt though) or both.
>>> Thanks.
>>> Mo
>> Google
>>> gdal_translate
>>>> Date: Thursday, April 9, 2009, 12:44 AM
>>>> Granted, I haven't
>>> tried V 5 yet,
>>>> but your quote also states, "Google Earth
>> Pro or
>>>> EC". Are you using one of those versions
>> of
>>> the
>>>> client? In any case, if the file opens in
>> OpenEV,
>>> chances
>>>> are good that the .ntf generated by gdal is ok,
>> and
>>> that
>>>> there is some sort of problem with how Google
>> Earth
>>> is
>>>> reading it. Have you tried emailing the KML
>> support
>>> list
>>>> as well?
>>>> On Wed, Apr 8, 2009 at 8:51 PM,
>>>> wrote:
>>>> Google Earth 5.0 supports NITF see
>>>> http://earth.google.com/intl/en/userguide/v5/ug_importdata.html
>>>> [Importing Imagery
>>>> You can open GIS imagery files in Google Earth
>> Pro or
>>> EC
>>>> and have the files correctly projected over the
>> proper
>>> map
>>>> coordinates in the 3D viewer. Google Earth Pro
>> and EC
>>>> support the following types of GIS imagery:
>>>> * TIFF (.tif), including GeoTiff and
>> compressed
>>> TIFF
>>>> files
>>>> * National Imagery Transmission Format
>> (.ntf)
>>>> * Erdas Imagine Images (.img)
>>>> In addition, you can also import the following
>>> images.
>>>> Because they do not contain projection
>> information,
>>> you must
>>>> manually edit their coordinates for correct
>>> positioning:
>>>> * Atlantis MFF Raster (.hdr)
>>>> * PCIDSK Database File (.pix)
>>>> * Portable Pixmap Format (.pnm)
>>>> * Device Independent Bitmap (.bmp)
>>>> Note - All imagery files must contain the
>> correct
>>>> projection information in order to be accurately
>>>> re-projected by the Google Earth software.]
>>>> Mo
>>>> --- On Wed, 4/8/09, Roger André <randre at gmail.com>
>> to
>>> Google
>> by
>>>> gdal_translate
>>>>> Date: Wednesday, April 8, 2009, 10:45 PM
>>>>> See http://earth.google.com/userguide/v4/ug_imageoverlays.html#requirements,
>>>>> I don't believe the "NITF (rw+):
>>> National
>>>> Imagery
>>>>> Transmission Format" is supported by
>> Google
>>>> Earth.
>>>>> Roger
>>>>> On Wed, Apr 8, 2009 at 3:27 PM,
>>>>> wrote:
>>>>> Hi all,
>>>>> I'm sorry that this is the third time I
>> tried
>>> to
>>>> send
>>>>> this message out because I myself didn't
>> get
>>> the
>>>> first
>>>>> two through gdal-dev at lists.osgeo.org
>>>>> so I thought others might not get it
>> either.
>>>>> I used gdal_translate to convert a tif image
>> to
>>> a
>>>> nitf
>>>>> image as:
>>>>>> gdal_translate -of nitf in.tif out.ntf
>> -co
>>>> ICORDS=G
>>>>> Input file size is 561, 420
>>> 0...10...20...30...40...50...60...70...80...90...100
>>>>> done.
>>>>> I can display both in.tif and out.ntf with
>>> OpenEV. So
>>>> both
>>>>> in.tif and out.ntf were ok to OpenEV.
>>>>> With a simple Google Earth kml
>> file(specifying
>>> the
>>>>> LanLonBox)(printed below) I could import
>> the
>>> in.tif
>>>> to
>>>>> Google Earth viewer to the right
>> geo-location.
>>> So
>>>> in.tif was
>>>>> ok to GE.
>>>>> However, after replacing the image file
>> name
>>> from
>>>> in.tif to
>>>>> out.ntf in the same kml file (printed below)
>> I
>>> could
>>>> not
>>>>> import the out.ntf to Google Earth viewer
>> (shown
>>> as a
>>>> big
>>>>> red cross in a big red rectangle at the
>>> geo-location
>>>> in the
>>>>> GE viewer). So out.ntf was not ok to GE.
>> Any
>>> ideal
>>>> about
>>>>> what might cause the problem? Was the use
>> of
>>>> gdal_translate
>>>>> wrong or missing some options? I tried not
>> to use
>>> -co
>>>>> ICRODS=G but I got the same problem. Thank
>> you.
>>>>> printed kml for in.tif:
>>>>> <?xml version="1.0"
>>>>> encoding="UTF-8"?>
>>>>> <kml xmlns="http://www.opengis.net/kml/2.2"
>>>>> xmlns:gx="http://www.google.com/kml/ext/2.2"
>>>>> xmlns:kml="http://www.opengis.net/kml/2.2"
>>>>> xmlns:atom="http://www.w3.org/2005/Atom">
>>>>> <GroundOverlay>
>>>>> <description>
>>>>> *** Meta-Data ***
>>>>> Lat = 42.808863
>>>>> </description>
>>>>> <name>in.tif</name>
>>>>> <Icon>
>>>>> <href>in.tif</href>
>>> <viewBoundScale>0.75</viewBoundScale>
>>>>> </Icon>
>>>>> <LatLonBox>
>>>> <north>42.8093748999134</north>
>>>> <south>42.8082925732318</south>
>>>> <east>-70.887525562763</east>
>>>> <west>-70.8894939447889</west>
>>>> <rotation>-95.909027</rotation>
>>>>> </LatLonBox>
>>>>> </GroundOverlay>
>>>>> </kml>
>>>>> printed kml for out.ntf: same as in.tif
>>>>> except:
>>>>> <name>out.ntf</name>
>>>>> <Icon>
>>>>> <href>out.ntf</href>
>>>>> </Icon>
>>>>> Best Regards,
>>>>> Mo Wang
>>>>> gdal-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
