[gdal-dev] Problem with OGRCreateCoordinateTransformation
Reinaldo Escada Chohfi
rec at geodesign.com.br
Fri Apr 10 10:48:13 EDT 2009
Hello,
The code compiles because it is part of a bigger program. This is
just the portion on Coordinate Transformation.
Any additional comment is welcomed.
I did not compile GDAL. I am using gdalwin32exe141 & gdalwin32dev141
pre-built GDAL.
Thanks for your help.
Reinaldo
At 01:25 AM 4/10/2009, Howard Butler wrote:
>On Apr 9, 2009, at 9:38 PM, Reinaldo Escada Chohfi wrote:
>>Hello all,
>>We place this piece of code to test how coordinate transformation
>>works with OGR.
>> OGRSpatialReference oSourceSRS, oTargetSRS;
>> OGRCoordinateTransformation *poCT;
>> double x1, y1;
>> oSourceSRS="EPSG:4326";
>> oTargetSRS="EPSG:4989";
>I don't see how this could compile. You need to instantiate
>oSourceSRS and oTargetSRS with OSRNewSpatialReference, and then use a
>call like OSRImportFromEPSG or OSRSetFromUserInput on the objects to
>get valid SpatialReferences.
>>The program compiles fine, but it gives the following runtime error:
>>ERROR 6: Unable to load PROJ.4 library (proj.dll), creation of
>>OGRCoordinateTransformation failed.
>>Isn't PROj.4 (proj.lib) built in OGR?
>No, it is loaded at runtime unless you use have PROJ_FLAGS = -
>DPROJ_STATIC in your nmake.opt when you compile. Otherwise, you must
>ensure that GDAL_DATA and/or PROJ_LIB environment variables are set,
>and the necessary data can be found in those locations *and* the
>proj.dll that was linked with GDAL at compile time is able to be found
>at runtime.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090410/939d9e53/attachment.html
