[gdal-dev] Problem in importing to Google Earth a nitf image
converted from a tif image by gdal_translate
mohwawang
mohwawang at yahoo.com
Fri Apr 10 11:49:55 EDT 2009
Vincent,
I tried gdalwarp as:
>gdalwarp in.tif out.tif
ERROR 1: Unable to compute a transformation between pixel/line and georeferenced coordinate for in.tif.
There is no affine transformation and no GCPs.
I guess gdalwarp needs GCPs in in.tif that does not have GCPs in it.
I also tried gdal_translate again and this time I used -a_ullr as:
>gdal_translate -of GTiff in.tif out.gtf -a_srs EPSG:4326 -a_ullr -70.887525562763 42.8093748999134 -70.8894939447889 42.8082925732318
Then gdalinfo showed correct corner coordinates. But GE still could not import the out.gtf.
Mo
>gdalinfo out.gtf
Driver: GTiff/GeoTIFF
Files: out.gtf
Size is 561, 420
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-70.887525562763003,42.809374899913401)
Pixel Size = (-0.000003508702363,-0.000002576968290)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_XRESOLUTION=300
TIFFTAG_YRESOLUTION=300
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -70.8875256, 42.8093749)
Lower Left ( -70.8875256, 42.8082926)
Upper Right ( -70.8894939, 42.8093749)
Lower Right ( -70.8894939, 42.8082926)
Center ( -70.8885098, 42.8088337)
Band 1 Block=561x4 Type=Byte, ColorInterp=Red
Band 2 Block=561x4 Type=Byte, ColorInterp=Green
Band 3 Block=561x4 Type=Byte, ColorInterp=Blue
--- On Fri, 4/10/09, Vincent Schut <schut at sarvision.nl> wrote:
> From: Vincent Schut <schut at sarvision.nl>
> Subject: Re: [gdal-dev] Problem in importing to Google Earth a nitf image converted from a tif image by gdal_translate
> To:
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Date: Friday, April 10, 2009, 3:15 AM
> mohwawang wrote:
> > Hi Roger,
> > gdalinfo gave me only info about coordinates of GCPs
> but I doubt that are much useful to GE. Any other way (other
> than using GCP in gdal_translate) to embed the coordinates
> info to the GeoTIFF file?
> Mo,
> I doubt GE will read and use your gcp's. And as there is
> not georeferencing (as: standard geotiff georeferencing) in
> your tiff, GE will fail to place your image.
> I'd try to run your tiff through gdalwarp instead of
> gdal_translate. Good chance that gdalwarp will convert your
> unprojected image with gcp's into a real projected geotiff.
> Just try: 'gdalwarp <inimage.tif>
> <outimage.tif>' and then check your outimage with
> gdal_info. It should now give you proper lat/lon values for
> the corner coordinates, instead of pixel indices.
> Vincent.
> > Thanks.
> > Mo
> > Files: gdal_translate_tif_to_gtiff.gtf
> > Size is 561, 420
> > Coordinate System is `'
> > GCP Projection = GEOGCS["WGS
> 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
> > GCP[ 0]: Id=1, Info=
> > (0,0)
> -> (-70.887525562763,42.8093748999134,0)
> > GCP[ 1]: Id=2, Info=
> > (560,0)
> -> (-70.887525562763,42.8082925732318,0)
> > GCP[ 2]: Id=3, Info=
> > (560,419)
> -> (-70.8894939447889,42.8082925732318,0)
> > GCP[ 3]: Id=4, Info=
> > (0,419)
> -> (-70.8894939447889,42.8093748999134,0)
> > Metadata:
> > AREA_OR_POINT=Area
> (pixels/inch)
> > INTERLEAVE=PIXEL
> > Corner Coordinates:
> > Upper Left ( 0.0,
> 0.0)
> > Lower Left ( 0.0, 420.0)
> > Upper Right ( 561.0, 0.0)
> > Lower Right ( 561.0, 420.0)
> > Center ( 280.5,
> 210.0)
> > --- On Thu, 4/9/09, Roger André <randre at gmail.com>
> wrote:
> >> From: Roger André <randre at gmail.com>
> by gdal_translate
> >> To: "mohwawang" <mohwawang at yahoo.com>
> >> Date: Thursday, April 9, 2009, 4:30 PM
> >> Hi Mo,
> >> What is the gdalinfo output for the GeoTIFF that
> you
> >> created? If you didn't get an error when you
> tried to
> >> load it in GE, perhaps the georeferencing in the
> image
> >> doesn't quite match what you specified in your
> KML.
> >> Roger
> >> On Thu, Apr 9, 2009 at 1:21 PM,
> >> mohwawang <mohwawang at yahoo.com>
> >> wrote:
> >> Hi Roger,
> >> My goal is to be able to directly import NITF
> image to GE
> >> without using KML. You can see the advantage of
> this
> >> application - if it works. I'm glad that you have
> viewed
> >> in GE georeferenced imagery created or altered by
> gdal.
> >> Maybe you can point out what I did wrong.
> >> It is good that you asked about GeoTIFF. So I
> used
> >> gdal_translate to convert the tif image to a
> GeoTIFF image.
> >> I tried to drag and drop the GeoTIFF image to GE
> but nothing
> >> happened. I did not see the GeoTIFF image in GE
> and I did
> >> not get any error message either.
> >> I can open the GeoTIFF image with OpenEV and I can
> read the
> >> lan/lon coordinates and they are correct. One
> thing is that
> >> it seems that OpenEV does not set North to Up.
> Its
> >> orientation aligns with the file coordinates -
> (0,0) is at
> >> the upper left corner. I then opened tif file in
> the same
> >> OpenEV and they match to each other.
> >> Again, I can import the tif image with its kml to
> GE but I
> >> can not import the GeoTIFF to GE (without using
> kml), it
> >> seems that nothing happened. I can import the
> GeoTIFF to GE
> >> with kml - though that is not what I want. But the
> GeoTIFF
> >> is better than the NITF that could not be imported
> to GE
> >> even with the same kml.
> >> What's wrong with GeoTIFF? I mean why I could not
> >> import it to GE? I listed the gdal_translate
> command line
> >> here:
> >>> gdal_translate -of GTiff tiff.tif gtiff.gtf
> -a_srs
> >> EPSG:4326 -gcp 0 0 -70.887525562763
> 42.8093748999134 -gcp
> >> 560 0 -70.887525562763 42.8082925732318 -gcp 560
> 419
> >> -70.8894939447889 42.8082925732318 -gcp 0 419
> >> -70.8894939447889 42.8093748999134
> >> I don't have a .ntif file that was not created by
> gdal
> >> to test GE via the "Import Image Tool".
> >> Thanks.
> >> Mo
> >>> Subject: Re:
> image by
> >> gdal_translate
> >>> Date: Thursday, April 9, 2009, 12:47 PM
> >>> Hi Mo,
> >>> Thanks for that
> pointer on the differences between GE
> >>> Layers and
> Places. I'll be sure to take a close
> >> look
> >>> at those links. I've had occasion in the
> past to
> >> view
> >>> georeferenced imagery in Google Earth, much of
> it
> >> created or
> >>> altered by gdal in some way, so this topic
> interests
> >> me.
> >>> I'm curious, is your goal to view the NITF
> format
> >>> specifically
> and to have GE read the internal
> >> georeferencing
> >>> info, or is it just to view the image in
> GE? It
> >> sounds
> >>> like you have already accomplished the latter
> using a
> >> KML
> >>> Ground Overlay and a tif, a method which has
> also
> >> worked
> >>> reliably for me in the past as well. I've
> also
> >> had
> >>> success with PNG and JPEG format files.
> Since in your .nitf test the
> georeferencing was
> >> supplied by
> >>> the KML file, the red "X" you are getting
> >> implies
> >>> to me that the image format isn't being
> correctly
> >>> interpreted by
> GE for some reason. The fact that
> >> Envi
> >>> chokes on it as well does seem to point to
> gdal as a
> >>> possible
> culprit, although the NITF format is not one
> >> that I
> >>> have seen very much. Have you tried
> importing the
> >> GeoTIFF
> >>> version of your file directly into GE Pro as
> well?
> >> Also,
> >>> do you have a .nitf file that was not created
> by gdal,
> >> and
> >>> which you could use to test GE via the "Add
> >> Image
> >>> Overlay" tool?
> >>> Roger
> >>> On Thu, Apr 9,
> 2009 at 8:37 AM,
> >>> mohwawang
> >>> wrote:
> >>> Roger,
> >>> I'm using
> Google Earth Pro 5.0. Thank you for the
> >>> suggestions.
> >>> Google Earth
> Pro 4.0 also supports importing NITF:
> >>> http://earth.google.com/userguide/v4/ug_importdata.html
> >>> that is for
> importing your data (including vector data
> >> and
> >>> imagery data) to the Places of Google Earth
> while http://earth.google.com/userguide/v4/ug_imageoverlays.html
> >>> is for "Using
> Image Overlays and 3D
> >> Models".
> >>> See http://earth.google.com/userguide/v4/ug_layers.html#layers_vs_places
> >>> for the
> difference between Layers and Places in GE.
> >>> This is the
> first time I'm importing
> >> geo-referenced
> >>> images to Google Earth Pro and so far I don't
> have
> >> much
> >>> luck. As I said that I could not use GE to
> import the
> >> NITF
> >>> images converted from gdal_translate (with
> EPSG:4326
> >> that is
> >>> the same projection, Simple Cylindrical
> projection, or
> >> known
> >>> as Lat/Lon WGS84 that GE uses). So I tried to
> narrow
> >> down
> >>> the problem. This time I imported to GE an
> native
> >> Erdas
> >>> IMAGINE image (.img) (with UTM projection that
> GE
> >> supports
> >>> too) but still failed. The later test case has
> nothing
> >> to do
> >>> with gdal and is purely a question for GE.
> That .img
> >> image
> >>> can be opened by both IMAGINE and OpenEV.
> >>> The NITF image
> (converted by gdal_translate) not just
> >> could
> >>> not be opened by GE it could not be opened by
> ENVI
> >> 4.1
> >>> either. It can be opened by OpenEV (tightly
> related to
> >> gdal)
> >>> though. So it could be a problem in either
> >> gdal_translate or
> >>> ENVI (I doubt though) or both.
> >>> Thanks.
> >>> Mo
> >>> --- On Thu,
> importing to
> >> Google
> image by
> >>> gdal_translate
> >>>> Cc:
> >>>> Date: Thursday, April 9, 2009, 12:44 AM
> Granted, I haven't
> >>> tried V 5 yet,
> >>>> but your quote also states, "Google Earth
> >> Pro or
> >>>> EC". Are you using one of those
> versions
> >> of
> >>> the
> >>>> client? In any case, if the file
> opens in
> >> OpenEV,
> >>> chances
> >>>> are good that the .ntf generated by gdal
> is ok,
> >> and
> >>> that
> >>>> there is some sort of problem with how
> Google
> >> Earth
> >>> is
> >>>> reading it. Have you tried emailing
> the KML
> >> support
> >>> list
> >>>> as well?
> >>>> On
> Wed, Apr 8, 2009 at 8:51 PM,
> wrote:
> Google Earth 5.0 supports NITF see
> >>>> http://earth.google.com/intl/en/userguide/v5/ug_importdata.html
> [Importing Imagery
> >>>> You
> can open GIS imagery files in Google Earth
> >> Pro or
> >>> EC
> >>>> and have the files correctly projected
> over the
> >> proper
> >>> map
> >>>> coordinates in the 3D viewer. Google Earth
> Pro
> >> and EC
> >>>> support the following types of GIS
> imagery:
> * TIFF (.tif), including GeoTiff and
> >> compressed
> >>> TIFF
> >>>> files
> * National Imagery Transmission Format
> >> (.ntf)
> >>>> * Erdas Imagine
> Images (.img)
> >>>> In
> addition, you can also import the following
> >>> images.
> >>>> Because they do not contain projection
> >> information,
> >>> you must
> >>>> manually edit their coordinates for
> correct
> >>> positioning:
> >>>> * Atlantis MFF
> Raster (.hdr)
> * PCIDSK Database File (.pix)
> * Portable Pixmap Format (.pnm)
> * Device Independent Bitmap (.bmp)
> >>>> Note
> - All imagery files must contain the
> >> correct
> >>>> projection information in order to be
> accurately
> re-projected by the Google Earth
> software.]
> >>>> Mo
> On Wed, 4/8/09, Roger André <randre at gmail.com>
> importing
> >> to
> >>> Google
> tif image
> >> by
> >>>> gdal_translate
> >>>>> Date: Wednesday, April 8, 2009, 10:45
> PM
> See http://earth.google.com/userguide/v4/ug_imageoverlays.html#requirements,
> I don't believe the "NITF (rw+):
> >>> National
> >>>> Imagery
> >>>>> Transmission Format" is supported by
> >> Google
> >>>> Earth.
> >>>>> Roger
> On Wed, Apr 8, 2009 at 3:27 PM,
> wrote:
> Hi all,
> I'm sorry that this is the third time I
> >> tried
> >>> to
> >>>> send
> >>>>> this message out because I myself
> didn't
> >> get
> >>> the
> >>>> first
> >>>>> two through gdal-dev at lists.osgeo.org
> so I thought others might not get it
> >> either.
> >>>>> I used gdal_translate to convert a tif
> image
> >> to
> >>> a
> >>>> nitf
> >>>>> image as:
> >>>>>> gdal_translate -of nitf in.tif
> out.ntf
> >> -co
> >>>> ICORDS=G
> >>>>> Input file size is 561, 420
> 0...10...20...30...40...50...60...70...80...90...100
> >>>>> done.
> >>>>> I can display both in.tif and out.ntf
> with
> >>> OpenEV. So
> >>>> both
> >>>>> in.tif and out.ntf were ok to OpenEV.
> With a simple Google Earth kml
> >> file(specifying
> >>> the
> >>>>> LanLonBox)(printed below) I could
> import
> >> the
> >>> in.tif
> >>>> to
> >>>>> Google Earth viewer to the right
> >> geo-location.
> >>> So
> >>>> in.tif was
> >>>>> ok to GE.
> However, after replacing the image file
> >> name
> >>> from
> >>>> in.tif to
> >>>>> out.ntf in the same kml file (printed
> below)
> >> I
> >>> could
> >>>> not
> >>>>> import the out.ntf to Google Earth
> viewer
> >> (shown
> >>> as a
> >>>> big
> >>>>> red cross in a big red rectangle at
> the
> >>> geo-location
> >>>> in the
> >>>>> GE viewer). So out.ntf was not ok to
> GE.
> >> Any
> >>> ideal
> >>>> about
> >>>>> what might cause the problem? Was the
> use
> >> of
> >>>> gdal_translate
> >>>>> wrong or missing some options? I tried
> not
> >> to use
> >>> -co
> >>>>> ICRODS=G but I got the same problem.
> Thank
> >> you.
> >>>>> printed kml for in.tif:
> <?xml version="1.0"
> encoding="UTF-8"?>
> <kml xmlns="http://www.opengis.net/kml/2.2"
> xmlns:gx="http://www.google.com/kml/ext/2.2"
> xmlns:kml="http://www.opengis.net/kml/2.2"
> xmlns:atom="http://www.w3.org/2005/Atom">
> <GroundOverlay>
> <description>
> *** Meta-Data ***
> Lat = 42.808863
> </description>
> <name>in.tif</name>
> <Icon>
> <href>in.tif</href>
> <viewBoundScale>0.75</viewBoundScale>
> >>>>> </Icon>
> <LatLonBox>
> <north>42.8093748999134</north>
> <south>42.8082925732318</south>
> >>>> <east>-70.887525562763</east>
> <west>-70.8894939447889</west>
> <rotation>-95.909027</rotation>
> </LatLonBox>
> </GroundOverlay>
> </kml>
> printed kml for out.ntf: same as in.tif
> except:
> <name>out.ntf</name>
> <Icon>
> <href>out.ntf</href>
> >>>>> </Icon>
> Best Regards,
> Mo Wang
> >> _______________________________________________
> >>>>> gdal-dev mailing list
