[Gdal-dev] 1-band TIFF FILE color ramp NEEDED
Roger André
randre at gmail.com
Sun Apr 12 11:30:18 EDT 2009
Sorry about that. It has to do with the little progress indicator that runs
when gdal processes a file. There are different ways of invoking it, and my
mileage varies with each of them. I think it is based on what version of
gdal you're using. Anyhow, 2 ways you can deal with this. I think with
your version of gdal you can just remove the import statement, line 14 (
gdal.TermProgress = gdal.TermProgress_nocb ), entirely. If that doesn't
work, just remove all 3 lines that have "TermProgress" in them. You won't
have a status indicator then to tell you how far along the coloring is, but
the program should run. Also, just fyi that the colorization won't be
incredibly fast. It takes around 5 minutes to color an image that is 2500 x
2500 pixels on my machine. There is obviously room for optimization here
On Sat, Apr 11, 2009 at 5:05 PM, alvarez00 <oalvarez00 at gmail.com> wrote:
> Hi Roger,
> I'm trying to run the python code you suggested but I keep getting this
> error :
> Traceback (most recent call last):
> File "discreet_gray2color.py", line 14, in <module>
> AttributeError: 'module' object has no attribute 'TermProgress_nocb' "
> I don't know if it's the version of gdal I'm using or something else. (i'm
> using gdal 1.4.1.0)
> thanks,
> Here's another way you can do it, a Python script that will create discreet
> color classes from a grayscale image. It uses a function named MakeColor
> which is currently set to work on Z values between 0 and 255. You can test
> it by converting your file into an 8-bit version (gdal_translate -scale -ot
> Byte <infile> <outfile> ), and then running the tool on it. Once you see
> how it works, it should be pretty simple to modify the function to deal
> with
> the actual ranges in your data.
> Roger
> On Thu, Apr 9, 2009 at 4:24 PM, alvarez00 <oalvarez00 at gmail.com> wrote:
> > I'm trying to make a color ramp for a 1-band tiff file or a jpeg. I have
> a
> > 1-band tiff file and I converted that tiff file into VRT. I was reading
> some
> > of the posts and some suggest to modify the VRT file and add a ColorTable
> > tag but that doesn't work. My objective is to show the tiff(or)jpeg on
> > google earth. I'm running version 1.4.1.0 of gdal. Below is the VRT file
> > without any modifications. What I modify was the
> > '<ColorInterp>Gray</ColorInterp>' to '<ColorInterp>Palette</ColorInterp>'
> > and added a ColorTable.
> > VRTDataset rasterXSize="1200" rasterYSize="1096">
> <SRS>GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
> 1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]]</SRS>
> > <GeoTransform> -1.2459079918952935e+02, 8.9964705882352915e-03,
> > 0.0000000000000000e+00, 4.2216820949146452e+01,
> > -8.9964705882352915e-03</GeoTransform>
> > <Metadata>
> > <MDI key="AREA_OR_POINT">Area</MDI>
> > </Metadata>
> > <VRTRasterBand dataType="Float32" band="1">
> > <Metadata/>
> > <NoDataValue>-3.40282346638529E+38</NoDataValue>
> > <SimpleSource>
> > <SourceFilename
> > relativeToVRT="1">GoesWest1V1561915.tif</SourceFilename>
> > <SourceBand>1</SourceBand>
> > <SrcRect xOff="0" yOff="0" xSize="1200" ySize="1096"/>
> > <DstRect xOff="0" yOff="0" xSize="1200" ySize="1096"/>
> > </SimpleSource>
> > </VRTRasterBand>
> > </VRTDataset>
> > View this message in context:
> http://n2.nabble.com/1-band-TIFF-FILE-color-ramp-NEEDED-tp2613963p2613963.html
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> #! /usr/bin/env python
> # Create a colored image based on LUT in MakeColor function
> # Author: Roger Andre, October 2008
> # Usage: discreet_gray2color.py <infile> <outfile>
> from osgeo import gdal
> import sys
> import numpy
> import os.path
> src_file = sys.argv[1]
> dst_file = sys.argv[2]
> out_bands = 3
> def MakeColor(z_value):
> '''LUT for color ramp. Keys are pixel values, hash values are RGB
> triplets.'''
> color_dict = {
> 0:[102,0,255],
> 25:[20,82,255],
> 50:[0,194,224],
> 75:[0,255,122],
> 100:[41,255,0],
> 125:[204,255,0],
> 150:[245,194,0],
> 175:[224,118,0],
> 200:[168,46,0],
> 225:[105,0,0],
> 250:[64,0,0],
> 255:[0,0,0]}
> key_list = color_dict.keys()
> key_list.sort()
> while len(key_list) > 0:
> last_val = key_list[-1]
> if z_value >= last_val:
> return color_dict[last_val]
> else:
> key_list.remove(last_val)
> # Print some info
> print "Creating %s" % (dst_file)
> # Open source file
> src_ds = gdal.Open( src_file )
> src_band = src_ds.GetRasterBand(1)
> # create destination file
> dst_driver = gdal.GetDriverByName('GTiff')
> dst_ds = dst_driver.Create(dst_file, src_ds.RasterXSize,
> src_ds.RasterYSize, out_bands, gdal.GDT_Byte)
> # create output bands
> band1 = numpy.zeros([src_ds.RasterYSize, src_ds.RasterXSize])
> band2 = numpy.zeros([src_ds.RasterYSize, src_ds.RasterXSize])
> band3 = numpy.zeros([src_ds.RasterYSize, src_ds.RasterXSize])
> # set the projection and georeferencing info
> dst_ds.SetProjection( src_ds.GetProjection() )
> dst_ds.SetGeoTransform( src_ds.GetGeoTransform() )
> # read the source file
> gdal.TermProgress( 0.0 )
> for iY in range(src_ds.RasterYSize):
> src_data = src_band.ReadAsArray(0,iY,src_ds.RasterXSize,1)
> col_values = src_data[0] # array of z_values, one per row in source data
> for iX in range(src_ds.RasterXSize):
> z_value = col_values[iX]
> # print z_value # uncomment to see what value breaks color ramp
> [R,G,B] = MakeColor(z_value)
> band1[iY][iX] = R
> band2[iY][iX] = G
> band3[iY][iX] = B
> gdal.TermProgress( (iY+1.0) / src_ds.RasterYSize )
> # write each band out
> dst_ds.GetRasterBand(1).WriteArray(band1)
> dst_ds.GetRasterBand(2).WriteArray(band2)
> dst_ds.GetRasterBand(3).WriteArray(band3)
> dst_ds = None
> http://n2.nabble.com/1-band-TIFF-FILE-color-ramp-NEEDED-tp2613963p2622398.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090412/44971650/attachment-0001.html
