[gdal-dev] How to make my GDAL code faster?
Benoît Andrieu
bea at ixsea.com
Thu Apr 16 04:24:08 EDT 2009
Hi Nicolas !
I would be interested to know what you finally did ! ^^
By "rolling mean", I think he suggests to not make all the computations for every window of 5x5 pixels.
If your mean uses a simple computation (average for example), you don't need to sum all the values for every window ; you can keep the previous results to make your computation.
About the multithreading, I don't use it in my code for the GDAL part (reading writing protected by mutexes) but I use it for the processing part.
Regards and bonne chance ! ^^
Benoît Andrieu
bea at ixsea.com
benoit.andrieu at gmail.com
----- Original Message -----
To: Frank Warmerdam ; gdal-dev at lists.osgeo.org
Sent: Wednesday, April 15, 2009 9:27 PM
Subject: Re: [gdal-dev] How to make my GDAL code faster?
Hy,
Thanks for your help Frank,it's allowed me to improve my program from 200s to 14s that's show a great progress.
I didn't understand what is "rolling mean" could you please explain me?
An other question, is it possible to make multithread process?
thanks a lot for your help
Best regards,
Nicolas
Once you overhaul things to operate on substantial swaths of data, there
may also be some other opportunities for optimizing within your algorithm
(rolling means, for instance) but first solve the big IO overhead bottleneck.
2009/4/15 Frank Warmerdam <warmerdam at pobox.com>
Nicolas DEGARNE wrote:
I read on help and /gdal.h/ File Reference that it could exist faster way so I have some ideas like : Merging the code to c++
Using Read/Write block
Use Tile/Block to accelerate the process
Use the Warpprocess to calulate windows mean's faster
I hope you understand my request and it was clear
Nicolas,
My advice would be to read an entire 5 line swath into a buffer, and
then operate within that buffer. Very small read/write operations
are pretty expensive with GDAL and your approach of reading five pixels
off one line as a single request is very very fine grained.
Switching to C++ will not help noticably (just reducing one level of
function call overhead, and a bit of extra checking the C API provides).
At this point there is little value in going to exact TIFF tiles or using
the block API.
The Warp API is also going to be very high overhead to compute means.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Nicolas Degarne
76 rue de Nancy
94170 Le Perreux
06 84 93 80 94
nicolas.degarne at gmail.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090416/ce1eaafc/attachment.html
