[gdal-dev] New OGR_GEOM_AREA special field
Daniel Morissette dmorissette at mapgears.com
Thu Apr 16 17:53:37 EDT 2009
No comments? I'll go ahead and commit support for the new OGR_GEOM_AREA
special field to trunk tomorrow then...
Daniel
Daniel Morissette wrote:
> Hi GDAL Dev's,
> I'd like to use a OGR SQL statement to filter features from a shapefile
> based on their area. e.g. keep only the large lakes in a water layer for
> instance.
> A simple way to allow this would be to add a new OGR_GEOM_AREA special
> field on OGRFeatures that calls the OGRSurface::getArea() method and
> would be handled similar to the OGR_GEOM_WKT and other special fields in
> OGRFeature::GetFieldAsString?().
> Another option could be to add operators on geometries in the SQL parser
> but that could be a bit more involved (e.g. "select ST_Area(geom) from
> I have created a ticket about this which includes a patch for the new
> OGR_GEOM_AREA special field:
> http://trac.osgeo.org/gdal/ticket/2949
> What would you think of adding this to the SVN trunk? Or can anyone
> provide hints on the way to implement operators on geometries since that
> would clearly be a better solution but I'm not clear on the best way to
> add this to the OGR SQL engine.
> Daniel
Daniel Morissette
http://www.mapgears.com/
