[gdal-dev] Re: Problem resampling with gdal_warp
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri Apr 17 03:51:45 EDT 2009
Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> It took 10 minutes to run and so far everything seemed to be OK.
> But when I changed resolution to -tr 2 2 gdalwarp really jammed.
> Process started and used all the processor time as usual,
> output tiff file was created, but after that everyhing just stopped.
> Processor load is zero and output tiff does not grow in
> size. The size of the output is 10240252 bytes and remains the same.
Sorry, I gave a bit wrong information. Gdalwarp process is alive and doing
something, but it is using only about 2-5% of the processor time, and memory
reserved by the process is increasing very slowly.
-Jukka-
