[gdal-dev] Problems building 1.6.0 with Xerces 2.7 on Solaris 10 / Sparc (1.5.x work)
Peter J Halls P.Halls at york.ac.uk
Fri Apr 17 05:53:01 EDT 2009
Got it: the problem proved to be libtool!  I've successfully built a working
version of GDAL 1.6.0 by adding the '--without-libtool' to configure and tested
this version using ogr2ogr to translate a gml file to ESRI Shapefile format.
Fascinating, as libtool itself is unchanged between 1.5.x and 1.6.0, yet will
build the one and not the other!  Ho hum.
Best wishes,
Peter
Rushforth, Peter wrote:
>  Peter,
> Is it possible that what's in /usr/appl/bin/solaris/sparc/include/
> is xerces 2.8 or other?
> Looks like a version issue to me, going by memory.
> Peter
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org
>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Peter J Halls
>> Sent: April 16, 2009 8:49 AM
>> To: gdal-dev at lists.osgeo.org
>> Subject: [gdal-dev] Problems building 1.6.0 with Xerces 2.7
>> Dear All,
>>     I'm sure that I've done something wrong, but cannot see
>> it!  I've pulled GDAL 1.6.0 and ran the same configure
>> command as for 1.5.x, seeking to include xerces  (for GML).
>> Configure failed to find the xerces libraries with both gcc
>> 3.3 and the Sun compilers; I also had to drop Jasper, as I do
>> not currently have this.  I got round the xerces problem for
>> the Sun compilers (but get a new set of errors from gcc) by
>> editing configure to add a reference to the XMLUni header
>> file, as follows:
>> #include <xercesc/util/XercesDefs.hpp>
>> #include <xercesc/util/XMLUni.hpp>
>> #include <xercesc/util/PlatformUtils.hpp>
>> However, GDAL then fails to build, with multiple link errors
>> of the same form as originally generated by configure:
>> Undefined                       first referenced
>>   symbol                             in file
>> int xercesc_2_7::XMLString::compareString(const unsigned
>> short*const,const unsigned short*const)
>> /usr/postel/gdal-1.6.0/ogr/ogrsf_frmts/o/.libs/iom_basket.o
>> unsigned short*xercesc_2_7::XMLString::replicate(const
>> xercesc_2_7::XMLFormatter&xercesc_2_7::XMLFormatter::operator<
> <(const unsigned
>> short*const) /usr/postel/gdal-1.6.0/ogr/ogrsf_frmts/o/.libs/writer.o
>> void xercesc_2_7::XMLString::catString(unsigned
>> xercesc_2_7::LocalFileFormatTarget::LocalFileFormatTarget(const
>> char*const,xercesc_2_7::MemoryManager*const)
>> Checking the sources, the header file requests appear to be
>> in order, so it would appear that I have some other problem
>> that is masked by my edit to configure.
>> My current configure statement is
>> ./configure 'CC=cc' 'CCC=CC'
>> '--with-oci-include=/usr/appl/oracle/solaris/solaris32/instant
> client10_1/sdk/include'
>> '--with-oci-lib=/usr/appl/oracle/solaris/solaris32/instantclie
> nt10_1/lib'
>> '--prefix=/usr/appl/bin/solaris/sparc' '--with-pcraster=internal'
>> '--with-png=internal' '--with-libtiff=internal'
>> '--with-geotiff=internal'
>> '--with-jpeg=internal' '--with-xerces'
>> '--with-xerces-inc=/usr/appl/bin/solaris/sparc/include/'
>> '--with-xerces-lib=/usr/appl/bin/solaris/sparc/lib/libxerces-c.so.27'
>> '--without-python' '--without-jasper'
>> Note that I have had to specify the libxerces-c.so.27, rather
>> than just libxerces-c.so as I did at GDAL 1.5.x - they are
>> the same version.
>> I can provide compilation logs, etc., should these be needed
>> to identify where I've gone wrong.
>> Thanks and best wishes,
>> Peter
>> Peter J Halls, GIS Advisor, University of York
>> Telephone: 01904 433806     Fax: 01904 433740
>> Snail mail: Computing Service, University of York,
>> Heslington, York YO10 5DD This message has the status of a
>> private and personal communication
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
