[gdal-dev] Get real and turf imaginary from complex float...
Derek Mueller
dmueller at trentu.ca
Fri Apr 17 12:13:47 EDT 2009
Thank you Frank,
I think I should have said, how do I get both the real and imaginary
numbers out as Float32, since ultimately I do want to calculate
magnitude (as you might have guessed). Then I could read the 'real' and
'imaginary' numbers into IDL as 2 separate tiffs do do the calculation.
I tried to import the CFloat32 directly into IDL/ENVI but it doesn't
like the '64-bit pixel'. Could there be a workaround by modifying tiff
tags to say the CFloat32 data are actually 2 separate 32-bit numbers?
Thanks,
Derek
Frank Warmerdam wrote:
> Derek Mueller wrote:
>> I am new to gdal and it looks very promising ...but I am trying to
>> make a geotiff with four bands from an RSat-2 SLC image but I don't
>> need or want the imaginary part of the CFloat32 for now.
>> So far I have been able to extract the data and warp it to my
>> favourite projection. Can gdal separate the CFloat32 and save the
>> just real part?
>> gdal_translate.exe "RADARSAT_2_CALIB:SIGMA0:product.xml" out.tif
>> gdalwarp -s_srs wgs84.prf -t_srs aeaIS.prf -r bilinear out.tif image.tif
> Derek,
> gdal_translate "RADARSAT_2_CALIB:SIGMA0:product.xml" -ot Float32 out.tif
> should be sufficient to discard the imaginary portion. I'm not aware
> of any
> easy way of taking the magnitude of the data which is also often
> desirable.
> Best regards,
*Derek Mueller
*Roberta Bondar Fellow in Northern and Polar Studies
Geography Department, Trent University
1600 West Bank Drive,
Peterborough, ON K9J 7B8
Tel: (705) 748-1011, ext. 7153,
Fax: (705) 748-1205
E-mail: dmueller at trentu.ca
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090417/a711cd02/attachment.html
