[Gdal-dev] gdaltransform v.1.6.0 - result differs from documentation
Jamie Adams jaadfoo at gmail.com
Sat Apr 18 17:01:59 EDT 2009
Looks like they may have added a towgs84 parameter to the proj definition
for 31370:
http://postgis.refractions.net/pipermail/postgis-commits/2008-May/000283.html
That would likely explain the shift - the documentation probably hasn't been
updated.
On Sat, Apr 18, 2009 at 1:53 PM, geep999 <geep999 at yahoo.co.uk> wrote:
> Hi,
> I have own-compiled gdal-1.6.0 on Linux - Slackware 12.2.
> The documentation for gdalwarp - http://www.gdal.org/gdaltransform.html  -
> shows
> an example and a result:
> Simple reprojection from one projected coordinate system to another:
> gdaltransform -s_srs EPSG:28992 -t_srs EPSG:31370
> 177502 311865
> Produces the following output in meters in the "Belge 1972 / Belgian
> Lambert 72" projection:
> 244510.77404604 166154.532871342 -1046.79270555763
> My gdaltransform (gdal-1.6.0) gives a different result:
> 177502 311865
> 244422.238366377 165970.24545029 0
> Is the example wrong? Is my gdal-1.6.0 somehow faulty?
> Can anybody duplicate this or explain the difference?
> Cheers,
> Peter
> http://n2.nabble.com/gdaltransform-v.1.6.0---result-differs-from-documentation-tp2657180p2657180.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090418/0cf125d6/attachment.html
