[Gdal-dev] gtiff file size compared to original tiff +wrld file
TJMartin tjmgis at gmail.com
Wed Apr 22 04:49:08 EDT 2009
Hi christian
many thanks for your help, i will run this later on today/overnight :)
I saw that Geoserver tutorail using the database to store the files but
think i will stick with using just files.
will postback later on if and when i get it all running
thanks again
Tim
Christian Müller wrote:
> Hi, I did this process last year many times and here is my experience
> 1) I assume you omitted the create options, your original tiff files are
> compressed, the new ones not.
> Look here http://www.gdal.org/frmt_gtiff.html, on the commandline it is
> -co
> "COMPRESS=JPEG" as an example.
> 2) Take a look at your tiles with gdalinfo, do the have a color table or
> more bands ?. If your tiles have
> more bands, (e. g. one for read, one for green and one for blue), use
> gdal_merge.py with -pct to produce a big picture
> having only one band and a color table. Create your tiles from the big
> picture. Geoserver will say thank you in terms
> of memory usage and cpu performance.
> 3) Decide, wich Geoserver module to use. There are 2 of them. There is a
> file based approach and a jdbc based
> approach (Module imagemosic-jdbc). If you want to store the whole stuff in
> a
> database, use gdal_retile.py to procude your
> tiles and pyramids and the imagemosic-jdbc module to import all the tiles.
> Both, gdal_retily.py and the imagemosaic-jdbc
> module were developed by me, if you have questions, ask.
> The documentation is here
> http://docs.codehaus.org/display/GEOTDOC/Image+Mosaicing+Pyramidal+JDBC+Plug
> in
> A tutorial for geoserver is here
> http://geoserver.org/display/GEOSDOC/Using+the+ImageMosaic+JDBC+Plugin
> christian
> TJMartin writes:
>> Hi All
>> I am just getting started with gdal, and i have done a search but couldnt
>> find an answer.
>> I currently have 10,000 tiff files with their world files. My real aim is
>> to
>> tile them up and make them easier to use in Geoserver or create an image
>> pyramid.
>> So i used gdal_translate to Geotiff, then was going to use gdalwarp to
>> mosaic, then tile them.
>> However the file size for geotiffs are between 4 and 15 times the size
>> 4mb to 60mb
>> One set were originally 128mb and now 858mb.
>> So if i was to mosiac these and then tile them it will still be a huge
>> data/size volume to server via geoserver.
>> So my questions
>> 1) Can i reduce the quality when translating to geotiff, and how much
>> will
>> this affect the image quality when i mosaic and tile
>> 2) Should i mosaic the tiff + world files instead and then tile them with
>> world files instead of using geotiffs
>> 3) is there  a better way of doing this?
>> would really appreciate anyone's help
>> all the best
>> Tim
>> View this message in context:
>> http://n2.nabble.com/gtiff-file-size-compared-to-original-tiff-%2Bwrld-file-tp2672921p2672921.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
View this message in context: http://n2.nabble.com/gtiff-file-size-compared-to-original-tiff-%2Bwrld-file-tp2672921p2674970.html
