[gdal-dev] gdal-1.6.0 Python binding on Windows
Even Rouault even.rouault at mines-paris.org
Wed Apr 29 14:23:26 EDT 2009
I don't use Windows myself, but Tamas Szekeres provides a
ready-to-use-and-compile SDK with multiple GDAL and MapServer versions and
MSVC versions. And it has support for Python bindings.
See http://vbkto.dyndns.org:1280/sdk/Default.aspx
Le Wednesday 29 April 2009 16:31:09 Gong, Shawn (Contractor), vous avez
écrit :
> hi list,
> I had asked how to build new-generation Python binding on Windows for
> gdal, but got no answer.
> (I know that on Linux, "configure --with-python" does it.  Couldn't find
> similar thing on nmake.opt)
> I did "nmake /f makefile.vc" and "nmake /f makefile.vc install"
> It created gdal16.dll in \local_install\bin and _gdal.dll in
> \local_install\pymod.
> gdal.py (dated 2005-08-04) is copied in \local_install\pymod.
> I downloaded the GDAL Python Bindings executable installer for Python
> 2.4 from http://pypi.python.org/pypi/GDAL/  (but I cannot use GDAL
> Windows Binaries, I need to build customized drivers)
> After installation, it created C:\Python24\Lib\site-packages\osgeo\ that
> contains: _gdal.pyd, _gdal_array.pyd, _gdalconst.pyd, gdal.py
> Its gdal.py is different than that in \local_install\pymod\ My question
> is: is there a conflict on two versions of gdal.py and _gdal.dll vs
> _gdal.pyd?
> When I call gdal.SerializeXMLTree() or gdal.Open(), python.exe crashes.
> It can be tracked to gdal16.dll, which probably attributes to the above.
> Appreciate help on how to build GDAL Python binding on Windows.
> thanks,
> Shawn
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
